Aller au contenu principal
Vacuum Cleaner Brush Roll Replacement
Ce dont vous avez besoin
  1. Vacuum Cleaner Brush Roll Replacement, Brush Roll: étape 1, image 1 de 1
    • Be sure to unplug the device from the wall outlet before disassembling.
    • Remove the bottom head of the vacuum cleaner by pressing the push button.
  2. Vacuum Cleaner Brush Roll Replacement: étape 2, image 1 de 2 Vacuum Cleaner Brush Roll Replacement: étape 2, image 2 de 2
    • Carefully unscrew the 6 screws with a Phillips screwdriver. Set aside.
  3. Vacuum Cleaner Brush Roll Replacement: étape 3, image 1 de 1
    • Separate the top portion of the head from the bottom.
    • Make sure not to pull off or damage the connected wires.
  4. Vacuum Cleaner Brush Roll Replacement: étape 4, image 1 de 1
    • Slip off the belt.
  5. Vacuum Cleaner Brush Roll Replacement: étape 5, image 1 de 2 Vacuum Cleaner Brush Roll Replacement: étape 5, image 2 de 2
    • Pull the brush roll from its slots.
  6. Vacuum Cleaner Brush Roll Replacement: étape 6, image 1 de 2 Vacuum Cleaner Brush Roll Replacement: étape 6, image 2 de 2
    • Use scissors to cut strings and other debris from the brush roll. Avoid cutting the bristles.
  7. Vacuum Cleaner Brush Roll Replacement: étape 7, image 1 de 1
    • Return the clean brush roll and re-situate the belt to secure it in place.
To reassemble your device, follow the disassembly instructions in reverse order.
Kaitlyn Sheets
Membre depuis le 01/19/16
117 Réputation
1 tutoriel rédigé
Équipe
Oakland University, Team 6-12, Walwema Winter 2016 Membre de l'équipe Oakland University, Team 6-12, Walwema Winter 2016
OAK-WALWEMA-W16S6G12
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 61
Total : 2,534
