Introduction
Through normal wear and tear or rough handling, saxophone corks can become damaged, rendering the instrument useless or operating at diminished quality. This guide will replace a Yamaha YAS-23 alto saxophone cork; however, the size for all alto saxophone neck-pieces is standard, so this repair is applicable to all alto saxophone neck-piece cork repairs.
For optimal performance, saxophones require a well fitting cork. Without this, tone quality will be sacrificed, or the saxophone will cease to function.
Ce dont vous avez besoin
Locate the screw on the side of the neck-piece, connecting the octave key to the neck-piece.
Use a small, 2.5 mm flat head screwdriver to remove the screw.
Use the utility blade to scrape off the cork.
Start at the base of the cork on the neck-piece with the utility blade at a 10 to 20 degree angle.
In a controlled motion, drag the utility blade along the neck-piece, removing cork along the way.
Repeat until all of the cork is removed.
With a damp microfiber cleaning cloth, wipe off any dust and glue particles.
Un commentaire
I’m usually here for computer guides, I couldn’t believe a sax guide was here! Was overjoyed! Can someone make a Alto Sax full pad replacement guide? I know it’s a big ask! But I have a YAS-23 and it needs all new pads, getting it serviced by a pro is between $700-$850!! But buying pads yourself is as low as $50 or on the high end $200. This seems like a tutorial the world needs to have! Thank you to anyone that even took the time to read this.
