Aller au contenu principal
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Desktop PC, utilisez notre manuel de réparation.
  1. Microdigital TK 85 Teardown, The TK 85 case and connectors: étape 1, image 1 de 3 Microdigital TK 85 Teardown, The TK 85 case and connectors: étape 1, image 2 de 3 Microdigital TK 85 Teardown, The TK 85 case and connectors: étape 1, image 3 de 3
    • 9V DC = Nomo P2 power supply
    • Expansão = Expansion connector 2x23 edge pins.
    • Joystick = Joystick connector DIN-6-07M.
    • Mic = audio output for a datacorder.
    • Ear = Audio input for a datacorder.
    • Video = RF chanel 3 VHF output.
  2. Microdigital TK 85 Teardown, Inside the TK85: étape 2, image 1 de 3 Microdigital TK 85 Teardown, Inside the TK85: étape 2, image 2 de 3 Microdigital TK 85 Teardown, Inside the TK85: étape 2, image 3 de 3
    • Open it carefully because of the 2 keyboard flat cables.
    • Those flat cables are very problematic
  3. Microdigital TK 85 Teardown, Keyboard removed: étape 3, image 1 de 2 Microdigital TK 85 Teardown, Keyboard removed: étape 3, image 2 de 2
    • The upper part of the case is the keyboard, but the keyboard itself is not removable.
    • The lower part of the case is just a plastic part.
  4. Microdigital TK 85 Teardown, The circuit board: étape 4, image 1 de 2 Microdigital TK 85 Teardown, The circuit board: étape 4, image 2 de 2
    • The circuit board is a very compact circuit board with dual layer traks.
  5. Microdigital TK 85 Teardown, Rom and Ram: étape 5, image 1 de 2 Microdigital TK 85 Teardown, Rom and Ram: étape 5, image 2 de 2
    • MM2716Q-5 => 16Kb Eprom
    • 52164KSF/N => 64kb Rom ? It is a custom Microdigital Rom compatible with the NMC2764.
    • MCM4116BC-15 => 8 x 16,348 bits Ram = 16Kb Ram
  6. Microdigital TK 85 Teardown, The RF generator: étape 6, image 1 de 3 Microdigital TK 85 Teardown, The RF generator: étape 6, image 2 de 3 Microdigital TK 85 Teardown, The RF generator: étape 6, image 3 de 3
    • Just a RF Chanel 3 VHF modulator.
  7. Microdigital TK 85 Teardown, Microchips identification: étape 7, image 1 de 2 Microdigital TK 85 Teardown, Microchips identification: étape 7, image 2 de 2
    • Microprocessor
    • Rom
    • Eprom
    • Ram
    • Oscilator 555. Works as an PWM 5 Volt power supply to the micropocessor.
    • Spare space for an audio integrated circuit. It was never implemented in producion in this model.
    • Voltage regulator 7805
    • Frequency divider = 6,5Mhz used for video and 3,25Mhz used for actual clock.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 36
Total : 849
