Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre iMac Pro, utilisez notre manuel de réparation.
  1. iMac Pro Teardown, iMac Pro Teardown: étape 1, image 1 de 2 iMac Pro Teardown, iMac Pro Teardown: étape 1, image 2 de 2
    • Our teardown iMac Pro sports these "entry-level" specs:
    • 8-core, 3.2 GHz Intel Xeon W processor with Turbo Boost up to 4.2 GHz
    • 32 GB (4 × 8 GB) of 2,666 MHz DDR4 ECC
    • AMD Radeon Pro Vega 56 GPU with 8 GB of HBM2 memory
    • 27" display with 5120 × 2880 resolution and support for one billion colors (P3 color gamut)
    • 1 TB SSD
    • Higher-end configurations with up to 18 processor cores will be available in a few weeks' time—if you're looking to spend $13,000 USD or more, that is.
    • We're prepared to sacrifice this unit in the name of science... but we're sure hoping not to. Fingers crossed that it goes back together in one piece!
  2. iMac Pro Teardown: étape 2, image 1 de 2 iMac Pro Teardown: étape 2, image 2 de 2
    • We can hardly contain our excitement as we unbox the magnificent Space Gray accessories—Magic Mouse, Magic Keyboard, and *gasp*
    • ... a black Lightning-to-USB cable.
    • We'll be back to continue the teardown after we recover from shock and peek out the window for signs of airborne ungulates.
    • Weirdly, there is still absolutely no provision—dongle or otherwise—for using the Lightning EarPods you get with your iPhone 7, 8, or X on your iMac Pro. Does it seem odd that these incompatible products are coming from, of all places, Apple?
    • Let's peel back the iMac Pro's fancy fabric wrapping and check the port situation ... just to be sure.
  3. iMac Pro Teardown: étape 3, image 1 de 3 iMac Pro Teardown: étape 3, image 2 de 3 iMac Pro Teardown: étape 3, image 3 de 3
    • Here's the connectivity sitrep:
    • 3.5 mm headphone jack
    • SDXC card slot
    • Four USB 3 ports
    • Four Thunderbolt 3 (USB-C) ports
    • 10 Gb ethernet port
    • In case you were wondering, this here is Apple model number A1862.
    • We tried sticking RAM in these slots on the back. It didn't work.
  4. iMac Pro Teardown: étape 4, image 1 de 3 iMac Pro Teardown: étape 4, image 2 de 3 iMac Pro Teardown: étape 4, image 3 de 3
    • We're betting the opening procedure will be the same as it was on the iMac 5K—which is to say, if you can use a pizza cutter, you can open an iMac Pro.
    • With all that glass out of the way, we have a perfect view of the iMac Pro's pristine interior. Say, wouldn't this make a lovely wallpaper for someone?
  5. iMac Pro Teardown: étape 5, image 1 de 3 iMac Pro Teardown: étape 5, image 2 de 3 iMac Pro Teardown: étape 5, image 3 de 3
    • The first component out is the enormous dual-fan cooler.
    • Looks like Apple sacrificed the 5K's full-size desktop hard drive (not that you'd want that in a pro machine) to make some room here.
    • Also sacrificed to the cooling gods: the external RAM access hatch. Sad face.
    • In exchange, we get a big rear vent and an 80% increase in cooling capacity.
  6. iMac Pro Teardown: étape 6, image 1 de 3 iMac Pro Teardown: étape 6, image 2 de 3 iMac Pro Teardown: étape 6, image 3 de 3
    • AirPort card functions are consolidated onto the main board—for some unknown reason, Apple ditched the modularity from the 5K model. But we did pick up this funky new retaining clip for the coax cables.
    • The power supply connects to the logic board by way of not one, not two, but four shiny terminals secured with Torx screws.
    • This design is much closer to what we saw on the 2013 Mac Pro than the plasticky connectors we're used to ripping out of the iMac 5K.
    • It also makes accessing logic board components (apart from the RAM of course) much, much easier. With the power supply tucked back into the rear shell, we can remove the board right away. Let's do that!
  7. iMac Pro Teardown: étape 7, image 1 de 3 iMac Pro Teardown: étape 7, image 2 de 3 iMac Pro Teardown: étape 7, image 3 de 3
    • With the board out, the first order of business is inspecting the RAM.
    • There's no way around it: getting here was a major undertaking compared with the dead-simple RAM access hatch on the back of all previous 27" iMacs.
    • That said, we have a spot of good news: these are standard 288-pin DDR4 ECC RAM sticks, with standard chips on board:
    • SKhynix H5AN8G8NAFR-VKC 2,666 MHz DDR4
    • We waste no time in testing a little upgrade: How does four 32 GB modules for a "Maxxed" total of 128 GB sound?
    • After speedily reassembling everything, we're pleased to report that the result is epic. If you want to try it at home, pick up a Memory Maxxer RAM Upgrade kit.
  8. iMac Pro Teardown: étape 8, image 1 de 3 iMac Pro Teardown: étape 8, image 2 de 3 iMac Pro Teardown: étape 8, image 3 de 3
    • Back to the business of taking things apart: next up are these twin "SSDs”.
    • Unlike a standard SSD, which has the controller logic onboard, these raw flash modules only have an interface buffer—the PCIe/NVMe controller lies elsewhere. More on that in a bit.
    • Under a couple stickers we find some Torx screws. Off they go!
    • Each blade is designated Apple EMC 3197, model 656-0061A.
    • Popping the shields off, we encounter some chips:
    • SanDisk SDRQF8DC8-128G (four per card, two top and two bottom, for a total of 512 GB × 2 = 1024 GB)
    • Apple 338S00285 power management IC (likely)
  9. iMac Pro Teardown: étape 9, image 1 de 3 iMac Pro Teardown: étape 9, image 2 de 3 iMac Pro Teardown: étape 9, image 3 de 3
    • Do you want to know what's hiding under this enormous heat sink? So do we. After twirling away a few more Torx screws and tossing aside the mounting springs, we have an answer:
    • One GPU, which sadly is BGA-soldered in place. And at the opposite side, one workstation-class Xeon processor—not soldered in place.
    • It's too early to say how feasible a CPU upgrade might be—the chip appears to be custom-made for Apple by Intel. But upgrades seem at least theoretically possible.
    • It might be nice if your $5,000+ workstation could get an upgrade once in a while, rather than a full replacement... right?
  10. iMac Pro Teardown: étape 10, image 1 de 2 iMac Pro Teardown: étape 10, image 2 de 2
    • We've cleared the board, and it's time for a rundown of the silicon:
    • Intel Xeon W-2140B (Skylake, 14 nm—likely an underclocked W-2145 to keep the temps in check), 3.2 GHz CPU with Turbo Boost up to 4.2 GHz, paired with what could well be a standard LGA 2066 socket
    • AMD S5J68 1747 GPEW0333S3 SS63HBN181747US40104 Radeon Pro Vega 56 GPU with integrated 8 GB of HBM2 memory (on-package)
    • Intel X723D733 E1 05780 (SR3PV?) - likely platform controller hub
    • AQUANTIA AQtion AQC107-B1-C PCIe to multi-gigabit ethernet controller
    • Pericom Semiconductors PI3PCIE3412AZHE PCIE 3.0 mux/demux switch
    • Apple/Universal Scientific Industrial (USI) 339S00428 00012021 Wi-Fi/Bluetooth module
    • Genesys Logic GL3227A SD 4.0 memory card controller, and Texas Instruments LP8565A13 (likely LED backlight driver)
  11. iMac Pro Teardown: étape 11, image 1 de 2 iMac Pro Teardown: étape 11, image 2 de 2
    • Flip side:
    • Cirrus Logic CS42L83 audio/DAC
    • 3x Infineon (formerly Primarion) PXE1110CDM and PXE1610CDN multiphase digital controllers
    • 2x Intel JHL6540 Thunderbolt 3 controller
    • International Rectifiers IR35217 power stage controller
    • Macronix MXIC MX25L4006EZNI CMOS serial flash memory
    • NXP PCAL6524 I/O expander
    • 4x Texas Instruments TAS5764L audio amplifiers
  12. iMac Pro Teardown: étape 12, image 1 de 2 iMac Pro Teardown: étape 12, image 2 de 2
    • Last but far from least, hovering near the SSD slots, we have two custom Apple chips:
    • Apple T2 339S00467 layered over SK Hynix H9HKNNNBRUMUVR-NLH LPDDR4
    • Apple 338S00268—this chip's a bit of a mystery. In our initial excitement we thought it was the rumored A10 Fusion coprocessor, first seen in the iPhone 7, but the package size is too small (roughly 7.4 mm each side). Best guess: this is an Apple/Dialog Semi power management IC.
    • The successor to the T1 chip introduced in 2016's MacBook Pro with Touch Bar, the T2 is tasked here with all the functions of the SMC, image signal processing for the camera, audio control, and SSD controller, and Secure Enclave, and a hardware encryption engine. Whew!
    • The downside to all this added functionality and security is a major headache if your iMac Pro ever has to be restored.
  13. iMac Pro Teardown: étape 13, image 1 de 3 iMac Pro Teardown: étape 13, image 2 de 3 iMac Pro Teardown: étape 13, image 3 de 3
    • With the logic board out of the way, we can extract the 500 Watt power supply.
    • Manufactured by AcBel Polytech Inc., it accepts 100-240 Volts AC, and packs a little silicon of its own:
    • STMicroelectronics STD4N80K5 3 A N-channel MOSFET
    • STMicroelectronics L6599A high-voltage resonant controller
    • ON Semiconductor NCP1336B current mode controller
    • Diodes Incorporated AP4310A dual operational amplifier w/ voltage reference
    • ON Semiconductor NCP1631 2-phase power factor controller
    • Diodes Incorporated AP2125K-4.2TRG1 300 mA LDO regulator
  14. iMac Pro Teardown: étape 14, image 1 de 2 iMac Pro Teardown: étape 14, image 2 de 2
    • This iMac's shell is looking a bit bare, but we're not done yet: the "enhanced stereo speakers" are next.
    • Early reports are that these speakers live up to the hype: they're the best-sounding speakers you can get on a Mac.
    • ...until, we suspect, you can pair it with a Homepod—which should take the whole experience to the next level. We won't know for sure until the Homepod finally hits shelves sometime in 2018. (Is it just coincidence that it looks a bit like a Mac Pro?)
  15. iMac Pro Teardown: étape 15, image 1 de 3 iMac Pro Teardown: étape 15, image 2 de 3 iMac Pro Teardown: étape 15, image 3 de 3
    Outil utilisé dans cette étape :
    Mako Driver Kit - 64 Precision Bits
    $39.95
    J'achète
    • We've scoured this chassis for parts, and there's not much left—except for the outrageously awesome spring-loaded hinge mechanism that supports the display.
    • If you opt for Apple's VESA mount adapter kit, you'll get to indulge in a rare moment of Apple-sanctioned disassembly of your iMac Pro: inserting a card in the back disengages the spring, unveiling the row of Torx screws securing the stand.
    • This is probably the one and only time Apple will sell you a screwdriver and tell you to have at it.
    • Of course, if you're reading this, there's a good chance you're already fully prepared.
  16. iMac Pro Teardown: étape 16, image 1 de 3 iMac Pro Teardown: étape 16, image 2 de 3 iMac Pro Teardown: étape 16, image 3 de 3
    • Time to take a closer look at that display. Turns out it uses the same display panel we found in the iMac 5K: LG Display model LM270QQ1.
    • That said, the cabling arrangement and webcam hardware have been moved around—so you can't swap displays between models.
    • We peel up the long strip of shielding along the bottom to reveal the chips:
    • Texas Instruments NH245 8-Bit Dual-Supply Bus Transceiver
    • Texas Instruments BUF16821 Programmable Gamma-Voltage Generator and Vcom Calibrator
    • Parade Technologies DP665 LCD Timing Controller
    • Texas Instruments TPS54320 3A synchronous step-down SWIFT™ converter
    • Texas Instruments TPS65168 High Resolution Fully Programmable LCD Bias IC for TV
  17. iMac Pro Teardown: étape 17, image 1 de 1
    • That's a wrap friends. Time to reassemble this beast with some fresh thermal paste and see how it fares as a gaming rig.
    • In case you were wondering: Yes, it goes back together just fine. We'll have a step-by-step upgrade guide for you soon!
  18. Dernières pensées
    • The RAM and CPU are both modular, meaning repairs and upgrades are a go—despite what Apple tells you.
    • The dual SSDs are modular, but custom-made by Apple, complicating replacement.
    • Cutting the tape to open the iMac isn't too hard (with the right tools), but it must then be replaced to complete any repair.
    • Key replaceable components are buried behind the logic board, requiring a lot of disassembly for access.
    • The loss of the external RAM access hatch makes for much more challenging upgrades compared with the 27" iMac 5K.
    • The GPU is BGA-soldered in place—potentially a major drawback on a "pro" workstation. No easy graphics upgrades are possible, so choose your configuration wisely.
    Indice de réparabilité
    3
    Indice de réparabilité de 3 sur 10
    (10 étant le plus facile à réparer)
101 commentaires
OOH FIRST COMMENT! either way, Apples getting closer and closer to the point where a mac will literally be one single part that will not be modular in any way. Apple says they save the environment as much as possible while sweeping the fact that they make their machines as hard to fix as possible under the carpet.
Aiden - Réponse
Wow you got here first!
Padraic Hoselton -
Apple bounces back and forth between more and less modularity with most new architectures. Claiming that there is some obvious trend here is silly and baseless.
Mark -
This comment aged like fine wine with the launch of the M1-based iMacs.
Ethan Zuo -
Liquid cooling? SSD in RAID 0?
Peter Gamble - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 25
7 derniers jours : 202
30 derniers jours : 873
Total : 290,580
