Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
No Screen Display
Laptop starts, but the screen doesn’t turn on.
Poorly Installed Memory
If the RAM is not properly seated on the motherboard, you will need to reseat it. To do this, take off the backplate and unplug the RAM from the motherboard. Next, plug it back in, pushing until the RAM stick clicks into place.
Faulty Memory
Non-functional memory will prevent your screen from turning on. You will need to replace the memory. This link is our guide to replacing memory.
Dead Battery
If the battery needs to be charged, the laptop won’t turn on. In this case, you will need to recharge your laptop.
Doesn't Receive Input From Keyboard
Laptop is unresponsive to keyboard input.
Laptop Doesn't Respond To Keyboard Input
If the laptop doesn’t respond to keyboard input, you may need to replace the keyboard, or use an external keyboard. You can use an external keyboard by plugging into a usb slot on the laptop.
Keys Are Missing
If keys are missing, they can likely be replaced. Check if your keyboard manufacturer sells loose keys.
Keys Are Sticking
If your keys stick when pressed, they will need to be cleaned or replaced. Aim a can of compressed air underneath the key, and blow air in until the key stops sticking. Carefully remove any debris. Click here to visit our keyboard replacement guide.
Computer Is Overheating
Laptop gets extremely hot.
Clogged Exhaust Vents
Check if the exhaust vents on the backplate are clogged with dust. If they are, you’ll need to clean them out with a can of compressed air.
Faulty CPU Fan
If you don’t hear a fan running while the laptop is getting hot, you’ll need to install a new CPU fan. Click here to visit our CPU Fan replacement guide.
Battery Won't Charge
Battery doesn’t charge, or doesn’t hold a charge.
Faulty Charging Cable
If your laptop doesn’t respond to the charging cable, you may try a new charging cable before replacing the battery.
Clogged Charging Port
The charging port is dirty or clogged. In this case, you’ll have to clean out the port with a can of compressed air, or a toothpick.
Faulty Battery
The battery may no longer be capable of taking/holding a charge. In this case, you will need to replace the battery with a new one. You can replace your battery with our guide here.
Files And Programs Load Slowly
The laptop takes a long time to open files and programs
Too Many Active Processes
Too many active processes will slow down your computer. Close all applications and browser tabs.
Faulty Hard Drive
Hard drives become slower over time, and eventually need to be replaced. If you find that programs and files are taking a very long time to start, you probably need a new hard drive. Click here to view our hard drive replacement guide.
Insufficient Memory
Active processes on your laptop compete for memory space, so if there’s not enough memory, things will slow down drastically. To fix this, you’ll need to buy more RAM, or purchase larger memory.
Laptop Doesn't Start/Randomly Shuts Down
Laptop will not start, or randomly shuts down.
Dead Battery
Laptop Has Malware
Computer viruses may cause unexpected problems with your laptop. To remove viruses, try booting from a live operating system disc, or run a virus scan.
Faulty Motherboard
If your computer is completely unresponsive, the motherboard may be broken. You will need to replace the motherboard with a new one. To view our replacement guide for a faulty motherboard, click here.
Faulty Battery
The battery is completely dead, and no longer capable of taking a charge. In this case, you will need to replace the battery with a new one. You can follow our battery replacement guide here.
Un commentaire
It's almost like it's stuck, it has rows of bubbles going up and down on the opening screen. Can't control mouse arrow on screen, it keeps moving around.
Patty Marshall - Réponse
