Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Laptop won't turn on
No matter what you do, you can't get your Acer to turn on.
Power Plugged in and On switch hit
Before delving into the guts of your Acer, make sure the power switch.... read on.
Drained/bad battery
If your Acer won't turn on, .... you may simply have a drained battery.
Bad display
It is possible that it appears nothing is happening because the display is bad. If .... it is possible the display is bad and must be replaced.
Hardware Problems/Replacement
Some of your hardware is not working properly or needs replaced.
Memory
If your Ram is outdated or under performing it may need to be replaced
Hard Disk Drive
Corrupted files or bad HDD it may need to be reformatted or replaced
Optical Drives
If your laptop wont read discs it may need to be cleaned or replaced
Touch Pads
If your laptop touch pad is unresponsive.. It may have loose connectors or need to be replaced
Keyboards
If your keyboard is unresponsive a simple cleaning may do the trick.
Software Problems
If your laptop powers on fine but your issue is in windows.
Device Drivers
Before wiping the contents or your laptop downloading the manufacturers updates may fix your issue
Operating Systems
It is possible your issue is a non compatible OS, check the manufacturers website for a compatibility list
Un commentaire
Why doesn't the Aspire 10 turn on when it's charging?
mewart - Réponse
