Merci à ces traducteurs :
en fr
100%
Annika Faelker nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
100%
Dernières 24 heures : 32
7 derniers jours : 234
30 derniers jours : 1,096
Total : 369,065
30 commentaires
The solution to a wrong bios update is to remove the bios chip reprogram with the update and put it back into the motherboard socket.
luisaparente - Réponse
how do you program it whilst it is removed.? Please reply on;trevermzbk@gmail.com
trevermsga - Réponse
I would like to know how you reprogram the chip, too.
Kevin Meisenbacher - Réponse
Same here
Will you Honor me with your knowledge?
@luisaparente
iorysrage - Réponse
if it's serial flash chip, you'll need simple serial programmer (SPI programmer), or built one. it's simple, you'll need some discrete passive elements, like resistors and couple of diodes, and also a serial/ parallel port, or USB-to-Serial adaptor, just check your search engine for details. But if your BIOS chip is parallel programmed, then you'll need more sophisticated microcontroller based programmer and special socket (usually PLCC32) to put flash chip in it. You can distinguish flash type by leg count. If it has 8 legs (DIP-8 package), its serial, if more (like 32 in PLCC32 package), then it's parallel.
Arbeit Ainstein -
