Aller au contenu principal
Kindle 3 Battery Replacement
Ce dont vous avez besoin
  1. Kindle 3 Battery Replacement, Battery: étape 1, image 1 de 3 Kindle 3 Battery Replacement, Battery: étape 1, image 2 de 3 Kindle 3 Battery Replacement, Battery: étape 1, image 3 de 3
    • Starting 15mm below the right page-turning button, insert the middle of the pry tool. Pry open the back of the device using the pry tool, or similar plastic opening tool. The flexi cable for the screen is 10mm wide and passes 10mm to 20mm below the right page turn and is very easy to tear the edge.
    • Do not attempt to pry directly on the page turning buttons. This will damage the buttons. By inserting it at 15mm this will reduce the chance of damaging the flexi cable. Look closely at the image of Kindle with the back removed, this will help to identify the location.
    • Be super careful here!! That flex cable is inherently tied into the screen, so if you damage the cable, the screen is ruined. Try opening from the other side, if possible. No single-points-of-failure to damage on that side.
    • If you are having trouble getting an initial gap to pry from, run the flat edge of the pry tool along the front-to-back plate seam until it slips into a gap.
    • Don't insert your tool too far, or you may damage some of the orange flex cables near the edges of the device.
    • When reinstalling the back cover, slide the bottom edge into place first, and then press up the sides and along the top until all the clips snap into place.
  2. Kindle 3 Battery Replacement: étape 2, image 1 de 1
    • Unscrew the two silver 4 mm Phillips screws securing the battery connector.
  3. Kindle 3 Battery Replacement: étape 3, image 1 de 3 Kindle 3 Battery Replacement: étape 3, image 2 de 3 Kindle 3 Battery Replacement: étape 3, image 3 de 3
    • Lift battery out of housing starting at the end that was secured by the screws.
    • Two silver washers beneath the battery connector may come loose—don't lose them.
    • When reinstalling the battery, first slide the bottom edge into place and make sure the two retaining tabs are secure, before screwing down the connector.
89 autres ont terminé cette réparation.
Allison Monahan
Membre depuis le 09/08/14
2 920 Réputation
2 tutoriels rédigés
Équipe
CSU Fullerton, Team 1-5, Bruce Fall 2014 Membre de l'équipe CSU Fullerton, Team 1-5, Bruce Fall 2014
CSUF-BRUCE-F14S1G5
4 membres
7 tutoriels rédigés
21 commentaires
Hi Allison Monahan,
thank you very much for yor help! By using your guide I made my nearly 6 years old Kindle Keyboard fixed - great!
Stefan Schiche - Réponse
I went to mpfproducts.com and ordered my new battery which came in today. I’ve changed out the battery and my Kindle 3 is now charging. YAHOO!!!
Ruth Kuykendall - Réponse
Where did you get the battery? I couldn’t find it on Amazon. Do you have a model number for the battery? Thanks.
sand1k -
The old Amazon link has been removed. There’s now a link at the top of this guide to an eBay vendor that stocks the battery. Good luck!
Jeff Suovanen -
Thanks, Allison and IFIXIT!!! God, I love this site. Cheers, Tom
tombeanhall - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 159
30 derniers jours : 729
Total : 66,439
