Aller au contenu principal
Repair guides and information for Microsoft's Surface Pro line of 2-in-1 tablets.
572 questions Voir tout
Need Microsoft Surface Pro Glass/Digitizer/LCD replacement parts.
I am the proud new owner of a Broken Surface Pro. The previous owner didn't see a use: but I want to fix it.
I can find replacements for the RT but nothing that is the spec of the Pro LCD. As removing the glass from the LCD is more laborious than just replacing the whole assembly; I would like to know if one is available?
Will the RT LCD/Digitizer work on the Pro?
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
11 Réponses
Réponse la plus utile
I'm in the process of repairing a Microsoft Surface Pro 128GB Model 1514 and can confirm that an RT digitizer will not work on the Pro. An important thing to keep in mind is that the digitizer and LCD in the Surface Pro are glued together and so you will most likely need an LCD to go with any digitizer you purchase. My recommendation would be to purchase a single digitizer/LCD assembly. In my case, thinking the two were seperate units ( as is the case with the iPad ), I purchased only the digitizer and later a separate LCD. Do what I did only if you feel comfortable taping the LCD to the digitizer.
Indice 1
1 commentaire:
where can you purchase the screen for a Microsoft Surface Pro 128GB I cannot seem to find any online
par
I can't seem to find anything but the LCD for the Pro. Answer to the RT Display working on the Pro is a big NO. Very different connectors.
Indice 0
1 commentaire:
Check Amazon they have it for 107.00
par
I found on eBay the glass only or the complete LCD kit in addition to the required tools
Indice 0
2 commentaires:
Buy the whole LCD and glass replacement removing just the glass is very hard and very easy to damage the LCD base. The glass is glued to the LCD bases and a big project separating the two!!!
par
please list seller's name
par
Hey anyone got any news on where to get new digitizer glass screens ?
i got a cracked screen surface pro off ebay cheap works perfect with the pen, obviously the touch doesnt work but since i do mostly zbrush and drawing touch really isnt a big deal to me.
i noticed on my unit that the cracked glass wants to flake of from a trasparent film underneath it so i am tempted to remove the glass (bit by bit and replace it with piece of regular glass cut from a glass shop.
while im certain this will pro negate the touch capability it may at least give me a non-cracked screen to look at.
before i go ahead with this though any suggestions from peeps
1 anyone know where to get a 3rd party replacement glass ? for less then 300 ?
2 anyone try removing the glass form the lcd ( i lifted up a 1/4inch from a corner very gently without damaging it so i know its possible.
3 anyone have any suggestions on using regular glass ?
Indice 0
1 commentaire:
1. The touch (digitizer) is normally part of the glass. Sometimes it isn't and regular glass can be used. I recommend avoiding 3rd party glass until you know which one you are dealing with. I have not seen any assemblies under $300. You might as well buy a DOA pro with a good screen assembly for around $300, that way you have some spare parts too and not just a screen assembly.
2. That clear film is likely LOCA. The same removal and replace process is similar to cell phones. It is very labor intensive and very risky for beginner repairs.
3. See #1.
par
For less than 300 (280 to be exact) Microsoft will replace your unit for you.. At least that is what they offer regarding my own cracked-glass-surface pro 2..
Indice 0
I have the same issue computer works perfectly but I have broken glass and probably a digitizer by the time I remove the broken glass. I found surface 2 glass and digitizer on eBay and everything looks the same from what I can tell by the pictures of anyone has that answer or a link to find one at a reasonable price I would be forever greatful. Thanks for the help Marland G
Indice 0
Do not but the replacement glass almost impossible to fix. Call microsoft will cost 300 to replace for a surface pro 128 but they exchange it for a working refurb
Indice 0
Hi any one have place sell Microsoft surface pro 2 touch glass RT pro not work cable its different connector check all place USA maybe son one have any information for fine this parts only touch glass ,my email its ferausa@gmail.com thanks all for attention
Indice 0
1 commentaire:
pls provide the model number (4 digit)to find the right part.surface has RT, PRO , PRO 2 , PRO 3.If u can provide the right model number then i can let u know whether i have in stock.its better for you to buy touch with lcd assembly which is easy to replace.if only the touch u r thinking to replace it is a long process and it takes long time to clean the glue on the lcd.
par
Hi I have sourced a part for the surface pro 3 lcd and digitizer replacement for $480 AU if you would like to talk further about it please contact me on kirby4446@me.com
Indice 0
2 commentaires:
Microsoft sells for $300
par
Except Microsoft won't tell it to you directly.
par
Hi everybody,
previous comments are old. Does anybody know where to buy the LCD + glass these days?
Thank you very much in advance
Indice 0
1 commentaire:
yeah sure, ebay!
Microsoft Surface Pro 1514 LTL106HL01-001 LCD Display Touch Digitizer Assembly
from oneby_tech for £55!
anyone needs the display or pen cable (kuma_pen_fpc) i'm selling on the same site (soon, cheaper than competition) message me!
par
Microsoft Surface Pro 1 1514 LTL106HL01-001 LCD broken glass .I have 7 for parts or what ever .caetanomagalhaes@hotmail,.com
Indice 0
1 commentaire:
i could sell all them or 1 by 1 From Edmonton Alberta Canada
par
Ajouter une réponse
volkswagenslave sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 21,110
