Aller au contenu principal
Audio Output Distortion on 3.5mm Headphone Jack
I've been using the machine everyday for many many years, especially for audio. One day I had the 3.5mm output plugged into a synthesizer to filter and mod the sound and some how some DC voltage leaked back into the mac and ever since then the port works, its just super noisy/distorted Whats even weirder is that the I get weird grounding noises/issues when I hook the mac DVI up to an external monitor. It gets amplified when I plug in the mag safe charger. These noises/issues can be heard thru the audio, even slightly when using a usb audio interface. Fortunately I have a parts unit to pull from. Has anyone seen this before? My first guess is to swap out the audio in/out board, but beyond that I dunno. If there are any board level repair guys who can give me advice. Thanks!
Update
So I did it and right when I got the audio board out I notice a blackened area, sure enough it toasted some resistors/caps, replaced the board and its all good! Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Not sure if changing out the audio board will fix this. Thats a good start.
Sounds like you blew one or more ground caps. The word 'Ground' here is a bit misleading we're really talking about the chassis frame. There are quite a few of these caps.
What happens when you use the optical link?
Indice 2
Ajouter une réponse
Brian Fox sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 3,390
