Aller au contenu principal
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 questions Voir tout
MacBook Pro slow battery charging
Hi
my macbook pro is very slow charging (about 10 hourse!)
there is (sometimes) horizontal line at start up (I repeat only sometimes)
I changed charger and battery but it doesn't solved
is this from logic board?
please help
Best Regards!
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
3 Réponses
Réponse la plus utile
The next step in the troubleshooting process would be to try and replace the magsafe port, if you indeed know its not the physical charger itself. This sits between your logic board and charger. If you are noticing slow charges and have eliminated the possibility of having a bad charger, it's possible your magsafe port is showing signs of its age. If I am not mistaken this is the part you should be looking for.
iFixit Guide
Edit = Repair Guide Link
Indice 2
4 commentaires:
thanks again for your reply
is this possible to test it with multimeter to understand dc in board is faulty?
best regards
par
Hi
I changed " magesafe DC in power board" but no luck!
please help!
what can I do?
Best Regards
par
I also have had this problem for quite a while. it isn't the magsafe DC-board so I suppose it's a chip that got short-circuit. But I have no clue where or what needs to be replaced..
par
Take it in to an ASP and have it tested for this issue:
MacBook Pro Repair Extension Program for Video Issues
https://www.apple.com/support/macbookpro...
Indice 1
2 commentaires:
Hi
thanks for your reply baaut in my country there is no apple service
pelase help
best regards
par
What country is that? We may know sources that you are not aware of.
par
Ordered one and will have at it this weekend. Hopefully this is the fix.
Indice 0
Ajouter une réponse
Nicolas sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 4,854
