Aller au contenu principal
Soldering 9 wires in wireles headphones
Hi,
I bought Powerbeats 2 that as turned out have damaged cable. I opened them, desolder all the wire and I'm left with 9 of these.
How should I connect them?
CABLE/WIRES - https://postimg.org/image/9gzv7i5jb/
BATTERY - https://postimg.org/image/zdtjk496v/
BATTERY (connected after opening) - https://postimg.org/image/5zxt4j6h3/
HEADPHONE - https://postimg.org/image/qlh6a6dfr/
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
Solution retenue
Here are the original wire locations:
Battery 1
Battery 2
Main Board 1
Main Board 2
Main Board 3
Volume Board 1
Volume Board 2
Volume Board 3
Volume Board 4
Indice 6
3 commentaires:
Where's the main circuit board that the mic and volume controls are on that have the I wanna say 5 but possibly 6 different wires soldered to it!???
par
sorry for the delay Clint here is the image. the wire between the blue and yellow is black if you can't tell in the image. It appears to only be 5 wires soldered, the 6th solder pad appears to be unused.
par
Thank you so much, never would've gotten this soldered correctly without those, you're a life saver!
par
Thanks you so much.
But could you please help me to let me know the Cable in Right Speaker (while and red-green) connect with what color in the long cable.
Thanks you so much guys.
Indice 1
3 commentaires:
I posted the answer to this I believe right above, please take a look...thanks
par
Hello sir, i have same problem with clint. I soldered the 3 wires in battery and it works.. But there are 3 more wires. The yellowred, the black, and the greenred..How do i connect for the right earbuds. Hope you're immediate response..
par
If this was for me, sorry for the delay...please post against my answer and you will get a quicker reply. Again the images are all above for every wire in the system
par
Ajouter une réponse
Tomek Dorobisz sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 6,675
