Phone stuck on apple logo after screen replacement
Hello everyone,
Okay, i replaced a iphone 6 phone screen yesterday and since the replacement, when i boot the device it is stuck on the boot screen?
I let the phone run out of battery, plugged it in and it was stuck on the charge icon. I done a hard reset and again no changes.
I have attached a video of the phone.
7 commentaires
Just had this happen with an 8 Plus. The connection for the front camera/earpiece was off by a hair. Disconnecting it and reconnecting it and feeling that "snap" fixed it. GL!
par John Corfman
Same problem (iphone 7). Found out my front camera flex cable was broken. I've ordered a new flex cable and hopefully a replacement will fix the problem.
par Erik Bylund
@Erik Bylund how can you conclude if it's broken if the screen is brandnew, not OEM, no signs of damage?
par ibisiki
@ibisiki Found out the problem was the front camera, there was a small cut in the cable. Probably broked it while replacing the screen. I removed it and then it worked.
par Erik Bylund
@ibisiki the screen was a refurbished original. Had to move Touch, cameras and sensors from the broken one.
par Erik Bylund
Voir 2 commentaires en plus
