Broken headphone jack/USB adapter
I have several Chromebook 3 tablets with broken headphone jacks. I recently purchased 2 of the Ugreen USB Sound Card External Audio Adapter with 3.5mm Aux. I plugged the adapter into the Chromebook and headphones into the adapter but the sound continues to come from the built in speakers and not through the adapter. I tested the adapter/headphones combination on my desktop PC and it worked as it should, sound through the headphones and not the PC.
Any ideas why it doesn't work on the Chromebook? Is there some internal setting I need to change or ???
1 commentaire
There is a tool, the GripStick, specifically designed to easily remove broken headphone plugs without having to disassemble the device, use glue, drilling, or any other unsafe method. It also works for any mobile device, tablet, computer, or any other electronic equipment that has a 3.5mm headphone jack.
https://www.youtube.com/watch?v=Ii5OKvtN...
It is made by Nightek (http://nightek.com/), and you can also buy it here on iFixit:
GripStick Headphone Plug Extraction Tool
par Nito
