Aller au contenu principal
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 questions Voir tout
Startup problems. Screen freezes to grey.
On startup screen freezes on grey with centre circle with diagonal line. I have tried starting holding various keys as suggested on internet sites - control, option, P and R; C; etc. nothing seems to work. The computer has been quite hot lately. Prob a 2010/2011 model. The power transformer also getting quite hot. Perhaps time for replacement of the lot?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Thanks but finally had to get another computer. An expensive fix!
par
Ajouter un commentaire
2 Réponses
Solution retenue
I had this issue with my MBP and it was because the GPU was starting to fail. I would recommend trying to force the intel GPU to run on startup and see if you can get back into MacOS that way by following the steps here:https://forums.macrumors.com/threads/for...
Indice 0
Réponse la plus utile
Sounds like your hard drive and/or HD cable is bad. Do you have a friend with a Mac that you can connect yours to? If you do see of you can run Disk Utility from your friends Mac to your attached system.
How to Boot a Mac in Target Disk Mode
Indice 2
1 commentaire:
Thank you Dan. Didn't have friend with apple so finally went to Apple itself. Hard drive ok (phew) but other problems suggested a new computer was in order. So that was the decision. Was able to transfer data myself via hard drive external reader.
par
Ajouter une réponse
Jennifer Mansfield sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,083
