Aller au contenu principal
Comment réparer son MacBook Pro 13" Unibody, modèle mi-2012, A1278, processeur 2,5 GHz i5 ou 2,9 GHz i7.
1624 questions Voir tout
Broken control key after heat sink replacement
Today, I replaced the heat sink on my 13 inch mid 2012 MacBook Pro. I had some difficulty getting the keyboard cable in, but in the end I got it all the way. The keyboard worked, or so I thought. Every single key works except the control key. The key seems fine - you can press it like any other key, but nothing happens when you press it. Could I have damaged the cable? I bent it a little bit but it doesn't look broken at all.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Try the control key on the other side of the keyboard.
Indice 2
1 commentaire:
There's only one control key on the left.
par
Open up the keyboard control panel (Apple Icon > System Prefs > Keyboard) Check off ‘Show keyboard and emoji viewers in menu bar' Note in the top right you should see a new menu icon click on it and open ‘Show Keyboard Viewer’
Now with the viewer on your screen test the control key does the key viewers icon show you pressing on the key?
The Control key doesn’t do much under MacOS so its hard to test.
Indice 1
2 commentaires:
No, like I said, the key does nothing when pressed.
par
In that case its time for a new keyboard as your key switch is bad ;-{
The cables connection is not the issue as then you would have multiple keys messing up. Think of it this way... A matrix of lines (X & Y) each switch connects one X wire with a Y wire to then tell the computer the input of that key. If one line was damaged then and key which connects to this line would also not work. Clearly thats not the case here so the given switch is bad.
par
Ajouter une réponse
Matthew Sigmond sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 36
