9 diagrammes
Questions populaires sur le forum
Poser une questionIl n'y a pas encore de questions. Soyez le premier à poser une question !
Documents
Modèles
536.881501
Background
The Craftsman Electric Snow Thrower, model number 536.881501, is a piece of equipment designed to assist in the removal of snow from outdoor areas. It is an electric-powered device, eliminating the need for manual labor associated with shoveling. This Snow Thrower is known for its durability and longevity, with the potential to remain operational for hundreds of hours of actual engine running time.
One of the primary features of this snow thrower is its 5 horsepower engine, which is designed to provide enough power to remove heavy snow with ease. The machine also includes a control flange that can be lubricated for smooth operation. Another key aspect of this machine is its ability to throw snow a significant distance, making it a suitable tool for clearing large driveways or pathways. Regular maintenance, such as oil changes, spark plug cleaning and inspection, and checking fuel and auger control cables, can enhance the performance and extend the engine life of this snow thrower.
Technical Specifications
- Model Number: 536.881501
- Product: Craftsman Electric Snow Thrower 536.881501
- Product Type: Electric Snow Thrower
- Horsepower: 5 HP
- Displacement: 148 cc
- Bore: 65mm (2.562 in.)
- Stroke: 45mm (1.750 in.)
- Oil Capacity: 5W30 (16 oz capacity)
- Spark Plug: Champion RJ19LM (Gap .030 in.) or equivalent
- Valve Clearance - Intake: 0.005-0.007 in.
- Valve Clearance - Exhaust: 0.007-0.009 in.
- Armature Air Gap: 0.006-0.010 in.
Warranty
The Craftsman Electric Snow Thrower 536.881501 comes with a limited two-year warranty. This warranty covers any defects in material or workmanship, and Sears will repair the snow thrower free of charge during this period. It is important to note that this warranty is valid only if the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. However, if the snow thrower is used for commercial or rental purposes, the warranty is only applicable for 90 days from the date of purchase. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. It also does not cover repairs necessary due to operator abuse or negligence. To claim the warranty, the Craftsman Snow Thrower should be returned to the nearest Sears service center in the United States. It is important to note that this warranty only applies while the product is in use in the United States.
