16 diagrammes
Questions populaires sur le forum
Poser une questionIl n'y a pas encore de questions. Soyez le premier à poser une question !
Documents
Modèles
536.886122
Background
The Craftsman Gas Snow Thrower 536.886122 is a gas-powered device used for removing snow from areas such as driveways or sidewalks. It is equipped with a 4-cycle engine with a model number 143.975001, offering suitable power for moderate to heavy snowfall conditions. The product features a 22-inch width dual-stage operation, which enables it to move large amounts of snow efficiently.
The snow thrower has an electric start feature, providing convenience and ease of use in cold weather conditions. It also includes various controls and adjustments, such as a choke, ignition key, auger drive lever, traction drive lever, crank assembly, electric starter, speed shifter lever, chute deflector, and recoil starter. Other features include a primer button and height-adjustable skids. The device uses a 120V power source for its electric start feature.
Technical Specifications
- Engine: 4-cycle, 5 horsepower
- Auger: 22 inch dual stage
- Electric start: 120V
- Snowthrower model number: 536.886122
Warranty
The Craftsman Gas Snow Thrower 536.886122 comes with a limited two-year warranty. This warranty covers any defects in material or workmanship for a period of two years from the date of purchase, as long as the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. However, please note that if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The following items are not covered by the warranty: spark plugs, drive belts, shear pins, and repairs necessary due to operator abuse or negligence. To claim the warranty, you can return the Craftsman Snow Thrower to the nearest Sears Service Center Department in the United States. It is important to note that this warranty is valid only while the product is in use in the United States.
