2 diagrammes
Questions de support
Poser une questionIl n'y a pas encore de questions. Soyez le premier à poser une question !
Modèles
SK-R-5/16EIC25
Background and Identification
The Electric Eel Drain Cleaner model SK-R-5/16EIC25 is made by Electric Eel Manufacturing, an Ohio-based drain cleaning equipment supplier that was founded in 1939. This is a drill drain cleaner, which means that it is a small, handheld cleaner that is best used for sinks and bathroom drains. The operator presses a trigger, which rotates a cable. The spinning cable dislodges blockages in the pipes. This drill drain cleaner is equipped with a cable that is 5/16” in diameter, and can clean out drains and pipes of up to 25 feet, with pipe diameters measuring up to 3 inches wide.
The cable and frame of this drill drain cleaner are made to resist rusting, which increases the lifespan of the tool. Users of this machine should note that it can have several different variations of cable. It is compatible with cable lengths between 225 and 35 feet, and the cables can have diameters of 1/4”, 5/16”, or 3/8”. The cable diameter and length that are needed depends on the plumbing issue. The operating manual has more information on what cable diameter should be used for a given pipe size in the ‘Operating Instructions’ section on page 3. For safety and hygiene, gloves should be worn at all times when operating this product, and the operator should follow all safety guides given in the product operating manual.
Technical Specifications
- Assembled Depth: 9 in
- Assembled Height:12 in
- Assembled Width:18 in
- Weight: 25 lbs
- Variable Speed: 0-600 RPM
- 120 VAC
- 60 Hz
- 3.2 amps
