Questions populaires sur le forum
Poser une questionIl n'y a pas encore de questions. Soyez le premier à poser une question !
General
The Elli Charger Standard serves as the base model within the Elli Charger lineup. It provides a convenient home charging solution for electric vehicles, delivering up to 11 kW of charging power. Equipped with an integrated charging cable, it's compatible with Type 2 connector-equipped EVs. This straightforward option offers a user-friendly way to charge your electric vehicle at home, devoid of the advanced smart features found in the higher-tier Elli Charger models.
Technical Specification
Product Configuration
Charging Mode | Mode 3 (IEC 61851) |
Access Control | - |
Internet- / Network Communication | - |
Communication Protocols | - |
Metering | - |
Electrical Properties
1 Phase | 3 Phase | |
Rated Voltage (± 10 %) | 1x 230 V | 400 V (3x 230 V) |
Rated Frequency | 50 Hz | |
Rated Current | 1x 32 A | 3x 16 A |
Max. Charging Capacity (depending on individual configuration) | 7,4 kW | 11 kW |
Charging Plug | AC – Type 2 | |
Charging Cable Length | 4,5 m or 7,5 m | |
Installation Wiring Cross Section | 1 – 10 mm2 | 1 – 6 mm2 |
Internal Earth Leakage Sensor | IΔn DC ≥ 6 mA (IEC 61851) | |
Additionally needed Upstream Protection | - Residual Current Detection minimum Type A (30 mA AC) - Circuit Breaker 32 A (1 Phase) or 16 A (3 Phase) |
Physical Properties
Dimensions [W x H x D] (in mm) | 297 x 406 x 116 |
Status Indication | LED based HMI |
Enclosure Ratings | IK 10 (IEC 62262) IP 54 (IEC 60529) |
Weight (depending on variant and charging cable length) | 5,6 kg … 7 kg |
Operating Temperature | -30 °C … +50 °C |
Max. Humidity | 95 % (non-condensing) |
Max. Altitude | 4000 m a.m.s.l. |
Mounting Method | On Wall |
Dynamic Load Management | via AC Current Sensors (optional additional material needed) |
