2 diagrammes
Questions populaires sur le forum
Poser une questionIl n'y a pas encore de questions. Soyez le premier à poser une question !
Modèles
Y6010-WK
Background
The Husky Air Compressor Y6010-WK is a mobile air compressor intended for home and vehicular applications. It is typically used to inflate tires and sports equipment, as well as to power air tools. This air compressor is characterized by its pancake-style design and a capacity of 6 gallons. It operates with a 1.5 HP oil-lubricated pump that delivers a maximum pressure of 150 PSI. At 90 PSI, it provides an airflow of 2.0 SCFM. The tank, made from rolled steel, is treated to resist corrosion. The device includes a universal quick connect coupler, a 25-foot hose, and an inflator/deflator accessory kit.
Weighing 32 lbs and measuring 18 x 18 x 19 inches, the Husky Y6010-WK is a compact model that is easy to transport. It is equipped with a pump that is thermally protected and will automatically shut off to prevent overheating. The Husky Y6010-WK is a versatile air compressor that is suitable for a wide range of tasks, from tire inflation and equipment cleaning to the operation of tools such as nail guns or air ratchets.
Technical Specifications
- Model Number: Y6010-WK
- Product Type: Portable Air Compressor
- Manufacturer: Husky Tools
- Tank Capacity: 6 gallons
- Pump Type: 1.5 HP oil-lubricated
- Max Pressure: 150 PSI
- Air Flow: 2.0 SCFM delivered at 90 PSI
- Tank Material: Rolled steel, corrosion-resistant
- Coupler: Universal quick connect
- Included Accessories: 25' hose, inflator/deflator kit
- Weight: 32 lbs
- Dimensions: 18 x 18 x 19 inches
- Protection: Thermal overload
Warranty
The Husky Air Compressor Y6010-WK comes with a 1-year limited warranty. This warranty primarily covers defects in materials and workmanship under normal usage conditions. However, it is noteworthy that wear parts, such as filters, are not included in the warranty coverage. To claim the warranty, the traditional processes generally involve providing proof of purchase and contacting the manufacturer's customer service, though the specific procedure may vary and should be verified with Husky Tools.
