1 diagramme
Questions populaires sur le forum
Poser une questionIl n'y a pas encore de questions. Soyez le premier à poser une question !
Documents
Modèles
XAG03Z
Background
The Makita XAG03Z is a cordless cut-off/angle grinder intended for various tasks such as grinding, cutting, and sanding materials including tile, concrete, pipe, and conduit. This 18V LXT Lithium-Ion Brushless Cordless grinder, featuring a brushless motor, provides extended run time, enhanced power and speed, and prolonged tool life. The model number can be identified on the product label, typically located on the side of the tool. The grinder features an ergonomic design, with dimensions of 14 x 5 x 5 inches, and comes in a factory color. However, it is no longer produced by the manufacturer.
Technical Specifications
- Dimensions: 14 x 5 x 5 inches
- Weight: 6 pounds
- Material: Factory
- Power Source: Hand Powered
- Voltage: 18 Volts
- Motor: Brushless
