1 diagramme
Questions populaires sur le forum
Poser une questionIl n'y a pas encore de questions. Soyez le premier à poser une question !
Documents
Modèles
9067L
Background
The Makita 9067L is a corded electric 7-inch angle grinder made in China. Designed for grinding, sanding, and polishing tasks, it has a 15.0 Amp motor with a no-load speed of 8,500 RPM. The angle grinder is recognized for its durable construction.
Technical Specifications
- Max. Capacities:
- Grinding wheel: 7" (180 mm)
- Wire cup brush: 4-3/8" (110 mm)
- Sanding disc: 7" (180 mm)
- Spindle thread: 5/8"-11 UNC
- No load speed: 8,500 RPM
- AMPS (120 V): 15.0
- Overall Length: 18" (458 mm)
- Net weight: 9.3 lbs (4.2 kg)
- Shipping weight: 14.7 lbs (6.7 kg)
- Amp Hours: 15.0 A
- Anti-Vibration Side Handles
Makita GA7001L Parts Breakdown
Makita 90679067S9067L 90699069S Angle Grinder Instruction Manual
