Aller au contenu principal
1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement
Ce dont vous avez besoin
  1. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: étape 1, image 1 de 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: étape 1, image 2 de 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement, Headlamp Unit: étape 1, image 3 de 3
    • Here is the Jeep GC. Removal of the headlamp is identical for both sides.
    • By opening the hood and looking straight down on the headlamp assembly, the 6mm hex head jack screw can be seen.
    • Use a 6mm socket and nut driver to remove the jack screw. 1/4 socket will not fit 9/32 does, but it is a bit sloppy
  2. 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: étape 2, image 1 de 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: étape 2, image 2 de 3 1999-2004 Jeep Grand Cherokee Headlamp Unit Replacement: étape 2, image 3 de 3
    • Remove the long jack screw.
    • Grasp upper inboard and lower outboard corners of headlamp and forcefully pull headlamp outward.
    • Remove all bulb sockets from headlamp module. Separate headlamp from vehicle.
6 autres ont terminé cette réparation.
oldturkey03
Membre depuis le 09/29/10
782 451 Réputation
119 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
33 membres
544 tutoriels rédigés
4 commentaires
It’s a 7mm socket
Don Marcos - Réponse
Not on mine. Just rechecked and it is a 6mm on my Jeep
oldturkey03 -
Thankful for simple instructions without any extra info or words ?
robinrogersk9 - Réponse
I’m removing it to replace fan cooling module. I heard I can cut through to get to it without disassembling the grill bumper etc
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 34
Total : 7,561
