Aller au contenu principal
Kindle Voyage Battery Replacement
Ce dont vous avez besoin
  1. Kindle Voyage Battery Replacement, Back Panel: étape 1, image 1 de 2 Kindle Voyage Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Battery Replacement: étape 2, image 1 de 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Battery Replacement: étape 3, image 1 de 3 Kindle Voyage Battery Replacement: étape 3, image 2 de 3 Kindle Voyage Battery Replacement: étape 3, image 3 de 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Battery Replacement: étape 4, image 1 de 2 Kindle Voyage Battery Replacement: étape 4, image 2 de 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Battery Replacement, Battery: étape 5, image 1 de 2 Kindle Voyage Battery Replacement, Battery: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
27 autres ont terminé cette réparation.
Sean Yap
Membre depuis le 01/22/15
1 253 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 19-12, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 membres
8 tutoriels rédigés
15 commentaires
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Réponse
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Réponse
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Réponse
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Réponse
Still looking for a source for this battery.
Neil Hall - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 89
30 derniers jours : 498
Total : 26,993
