Aller au contenu principal
1985-1988 Volvo 740 Brake Pads Replacement
Ce dont vous avez besoin
  1. 1985-1988 Volvo 740 Brake Pads Replacement, 1985-1988 Volvo 740 Preparing Car For Work: étape 1, image 1 de 2 1985-1988 Volvo 740 Brake Pads Replacement, 1985-1988 Volvo 740 Preparing Car For Work: étape 1, image 2 de 2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. 1985-1988 Volvo 740 Brake Pads Replacement, 1985-1988 Volvo 740 Jacking Rear Wheels: étape 2, image 1 de 1
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  3. 1985-1988 Volvo 740 Brake Pads Replacement: étape 3, image 1 de 2 1985-1988 Volvo 740 Brake Pads Replacement: étape 3, image 2 de 2
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame couple (pictured).
    • Only necessary to jack the car until the wheels are just off the ground.
  4. 1985-1988 Volvo 740 Brake Pads Replacement: étape 4, image 1 de 2 1985-1988 Volvo 740 Brake Pads Replacement: étape 4, image 2 de 2
    • Place jack stand on frame of car and remove jack.
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
  5. 1985-1988 Volvo 740 Brake Pads Replacement, Rear Brake Pads: étape 5, image 1 de 2 1985-1988 Volvo 740 Brake Pads Replacement, Rear Brake Pads: étape 5, image 2 de 2
    • Pry off the front hub caps by placing a small flathead screwdriver between hubcap and rim and pulling the screwdriver and hubcap away from tire.
  6. 1985-1988 Volvo 740 Brake Pads Replacement: étape 6, image 1 de 1
    • Loosen each of the five lug nuts on the rear left and rear right tires by turning them counter-clockwise with a 19mm socket wrench.
  7. 1985-1988 Volvo 740 Brake Pads Replacement: étape 7, image 1 de 1
    • Remove tires by pulling directly away from car exposing rear brake disks and calipers.
  8. 1985-1988 Volvo 740 Brake Pads Replacement: étape 8, image 1 de 1
    • Locate the two 17mm caliper guide bolts.
  9. 1985-1988 Volvo 740 Brake Pads Replacement: étape 9, image 1 de 1
    • Remove upper and lower guide bolts on rear left and rear right brake calipers with 17mm crescent wrench.
  10. 1985-1988 Volvo 740 Brake Pads Replacement: étape 10, image 1 de 1
    • Remove rear brake calipers from rotors.
  11. 1985-1988 Volvo 740 Brake Pads Replacement: étape 11, image 1 de 1
    • Locate the two rear brake pad retaining pins on each caliper.
  12. 1985-1988 Volvo 740 Brake Pads Replacement: étape 12, image 1 de 1
    • Remove brake pad retaining pins by punching them out with a 3mm allen key.
  13. 1985-1988 Volvo 740 Brake Pads Replacement: étape 13, image 1 de 1
    • Remove both rear brake pads by pulling them out of calipers.
  14. 1985-1988 Volvo 740 Brake Pads Replacement: étape 14, image 1 de 1
    • Insert two new brake pads into each caliper.
  15. 1985-1988 Volvo 740 Brake Pads Replacement: étape 15, image 1 de 1
    • Replace pin guide behind rear brake pads.
  16. 1985-1988 Volvo 740 Brake Pads Replacement: étape 16, image 1 de 2 1985-1988 Volvo 740 Brake Pads Replacement: étape 16, image 2 de 2
    • Verify that pins are inserted through caliper and brake pad holes and seated over the metal pin guides.
  17. 1985-1988 Volvo 740 Brake Pads Replacement: étape 17, image 1 de 1
    • Tap pins through both rear brake pads and caliper using a wrench.
  18. 1985-1988 Volvo 740 Brake Pads Replacement: étape 18, image 1 de 1
    • Replace rear calipers on rotors.
  19. 1985-1988 Volvo 740 Brake Pads Replacement: étape 19, image 1 de 3 1985-1988 Volvo 740 Brake Pads Replacement: étape 19, image 2 de 3 1985-1988 Volvo 740 Brake Pads Replacement: étape 19, image 3 de 3
    • Finish by performing steps 1-5 in reverse order.
Ligne d'arrivée
Garrett Van Ruiten
Membre depuis le 10/11/10
54 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-28, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 7,129
