Aller au contenu principal
1986-1993 Volvo 240 Spark Plug Wires Replacement
Ce dont vous avez besoin
  1. 1986-1993 Volvo 240 Spark Plug Wires Replacement, Spark Plug Wires: étape 1, image 1 de 1
    • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
  2. 1986-1993 Volvo 240 Spark Plug Wires Replacement: étape 2, image 1 de 2 1986-1993 Volvo 240 Spark Plug Wires Replacement: étape 2, image 2 de 2
    • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
    • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
Install your new spark plug wires in the same manner that you removed the old ones.
2 autres ont terminé cette réparation.
David Hodson
Membre depuis le 04/13/10
150 503 Réputation
127 tutoriels rédigés
2 commentaires
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - Réponse
These directions were great! Thank you. I got the wires on in about 40 minutes. Oh, and I’m a girlie girl. :)
Nancy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 11
Total : 4,019
