Introduction
Replace or clean (if applicable) the air filter every 12,000 miles to keep your vehicle running smoothly.
Outils
Pièces
The air filter housing is located on the driver side of the car. Loosen the four housing screws on the plastic air intake box.
  • The air filter housing is located on the driver side of the car.
  • Loosen the four housing screws on the plastic air intake box.
    • Do not try to remove these screws from the intake box, as they are not designed to be removed.
Ajouter un commentaire
Loosen the hose-clamp on the air intake tube located on the side of the air intake box. Remove the air intake tube from the intake box.
  • Loosen the hose-clamp on the air intake tube located on the side of the air intake box.
  • Remove the air intake tube from the intake box.
Gently lift the top off of the air intake box.
  • Gently lift the top off of the air intake box.
Remove the air filter from the housing and inspect it.
  • Remove the air filter from the housing and inspect it.
  • If it can not be cleaned, then it should be replaced with a new one.
Sank Yang
Membre depuis le 03/10/2012
345 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 9-15, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-15, Amido Fall 2012
CPSU-AMIDO-F12S9G15
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 21
30 derniers jours : 61
Total : 3,189
