Aller au contenu principal
1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation
Ce dont vous avez besoin
  1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: étape 1, image 1 de 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: étape 1, image 2 de 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: étape 1, image 3 de 3
    • Take the Philips screwdriver and remove two Philips head screws on both sides of the high mount brake lamp.
    • Be sure to store the two Philips screws in a safe place so they don't get lost.
  2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: étape 2, image 1 de 2 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: étape 2, image 2 de 2
    • Pull out the truck high mount brake/tail light housing.
    • We recommend you pull out the housing with both hands so you don't break the water tight seal.
    • If in the event that you happen you break it, you may have some water leak issues so you would have to fix the high mount brake/tail lamp housing with some glue.
  3. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: étape 3, image 1 de 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: étape 3, image 2 de 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: étape 3, image 3 de 3
    • Remove the stock bulbs from its socket.
  4. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: étape 4, image 1 de 1
    • Replace with the LED bulb.
    • Test your new LED truck high mount brake lamps to make sure everything works.
    • If the LED lights don't light up, check the polarity by flipping the bulbs 180 degrees.
  5. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: étape 5, image 1 de 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: étape 5, image 2 de 3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: étape 5, image 3 de 3
    • Put back the light housing and screw in the two Philips screws.
Test and enjoy your new LED truck high mount brake/tail replacement lights.
2 autres ont terminé cette réparation.
Eric Wu
Membre depuis le 01/21/15
3 357 Réputation
23 tutoriels rédigés
2 commentaires
The problem is there are no screws to remove.
richard - Réponse
there are no screws to remove on my 3rd light I can’t change the bulb
richard - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 30
Total : 5,982
