Aller au contenu principal
1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement
Ce dont vous avez besoin
  1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Plastic Rain Tray: étape 1, image 1 de 1
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 2, image 1 de 1
    • Remove the rubber gasket from the rain tray.
  3. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 3, image 1 de 1
    • Lift the tray upwards and away from the vehicle.
  4. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Front Windshield Wipers: étape 4, image 1 de 1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 5, image 1 de 1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  6. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 6, image 1 de 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 6, image 2 de 2
    • Gently lift up the passenger-side windshield wiper.
  7. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 7, image 1 de 1
    • Remove the driver-side windshield wiper in the same fashion.
  8. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: étape 8, image 1 de 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: étape 8, image 2 de 2
    • Lift up the plastic cover.
  9. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 9, image 1 de 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 9, image 2 de 2
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  10. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 10, image 1 de 1
    • Use a #2 Phillips screwdriver to remove the front two screws.
  11. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 11, image 1 de 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: étape 11, image 2 de 2
    • Gently unplug and lift out the automatic transmission control unit.
8 autres ont terminé cette réparation.
Matthew Newsom
Membre depuis le 01/05/10
39 527 Réputation
67 tutoriels rédigés
5 commentaires
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - Réponse
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - Réponse
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - Réponse
thank you very much .
emad_szs - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 134
Total : 43,758
