Aller au contenu principal
2000-2006 BMW M3 Oil & Filter Change
Ce dont vous avez besoin
  1. 2000-2006 BMW M3 Oil & Filter Change, 2000-2006 BMW M3 Oil & Filter Change: étape 1, image 1 de 1
    • Raise and support the car using ramps or jack stands. Never work under a car supported only by a jack.
    • The E46 M3 has four factory jack points (two per side), but you can also jack up the car using these two center points (one in front and one in the rear). Then you can easily place jack stands under the lift pads on the sideskirts/rocker panels.
    • Use this image for reference, but note that your exhaust configuration may look different. The car pictured is a Euro-spec M3 with cats in section I, whereas US-spec M3s have cats only in the headers.
  2. 2000-2006 BMW M3 Oil & Filter Change: étape 2, image 1 de 1
    • Open the hood to access the engine bay.
    • Note the oil filler cap (the large black plastic cap on the left) and the oil filter housing (the metal cylinder with the star pattern top on the lower right).
  3. 2000-2006 BMW M3 Oil & Filter Change: étape 3, image 1 de 1
    • Disconnect the throttle position sensor (simply pinch the clip and pull).
  4. 2000-2006 BMW M3 Oil & Filter Change: étape 4, image 1 de 1
    • Remove the oil filler cap by unscrewing it counter-clockwise.
  5. 2000-2006 BMW M3 Oil & Filter Change: étape 5, image 1 de 2 2000-2006 BMW M3 Oil & Filter Change: étape 5, image 2 de 2
    • Use a 13 mm socket to loosen the oil filter housing bolt.
    • Remove the bolt and set it aside. Some oil will drip, so have a shop rag or towel ready.
  6. 2000-2006 BMW M3 Oil & Filter Change: étape 6, image 1 de 2 2000-2006 BMW M3 Oil & Filter Change: étape 6, image 2 de 2
    • Beneath the car, remove the small round plastic cover that hides the oil drain plug (it's located in the middle of the aluminum underpanel, near the front center jack point).
    • Use a 6 mm hex/Allen socket to loosen the oil drain bolt, but don't remove it completely.
    • Position your oil drain pan below the bolt so that it will catch the used oil as it flows out.
    • Remove the bolt and allow the oil to drain.
  7. 2000-2006 BMW M3 Oil & Filter Change: étape 7, image 1 de 1
    • The oil filter kit comes with a replacement washer (sealing ring) for the drain bolt.
    • With the bolt removed, discard the old washer and replace it with the new one.
    • Reinstall the drain plug and torque it to 18 ft lbs.
    • Reinstall the plastic cover hiding the drain plug.
  8. 2000-2006 BMW M3 Oil & Filter Change: étape 8, image 1 de 1
    • Replace the rubber O-ring on the oil filter housing cap.
    • Give the new O-ring a light coating of fresh oil.
  9. 2000-2006 BMW M3 Oil & Filter Change: étape 9, image 1 de 2 2000-2006 BMW M3 Oil & Filter Change: étape 9, image 2 de 2
    • Replace the washer at the top of the oil filter housing bolt.
    • Replace the small rubber O-ring at the tip of the oil filter housing bolt.
    • You may need a pry tool to remove the old O-ring.
  10. 2000-2006 BMW M3 Oil & Filter Change: étape 10, image 1 de 2 2000-2006 BMW M3 Oil & Filter Change: étape 10, image 2 de 2
    • Replace the oil filter.
    • Put the cap back on the oil filter housing, and torque the bolt down to 24 ft lbs.
  11. 2000-2006 BMW M3 Oil & Filter Change: étape 11, image 1 de 2 2000-2006 BMW M3 Oil & Filter Change: étape 11, image 2 de 2
    • Using a funnel, pour about 5.75 liters of fresh oil into the oil fill hole.
    • Check the oil level and top up as needed. (The car should be level to the ground for an accurate reading.)
    • Close the oil filler cap.
    • Plug in the throttle position sensor.
    • Close the hood and lower the car. Re-check the oil level after a short drive and top up as needed.
    • Dispose of the old oil, filter, and any contaminated rags responsibly by taking them to a household hazardous waste facility. Many auto parts stores will also accept your used oil for disposal.
Ligne d'arrivée
5 autres ont terminé cette réparation.
Jeff Suovanen
Membre depuis le 08/06/13
428 506 Réputation
259 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 198 tutoriels rédigés
2 commentaires
Very good this is really nice
Nestor Gibbs sr - Réponse
Hi, can you please tell me what the green rectangles are on the jack point reference picture? I'm trying to use my lift but the my lift legs are too long, the m3 has a small wheelbase.
richbustamante2 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 99
Total : 20,218
