Aller au contenu principal
2001-2006 Mini Cooper Door panel Replacement
Ce dont vous avez besoin
  1. 2001-2006 Mini Cooper Door panel Replacement, Door panel: étape 1, image 1 de 2 2001-2006 Mini Cooper Door panel Replacement, Door panel: étape 1, image 2 de 2
    • The first step is to remove the door handle and speaker cover. This is easily done by prying it off the plastic tabs with a flathead screwdriver or possibly even your hands.
    • Next you need to remove the four size T30 torx screws that hold the panel in place. Three of these are in the obvious screw holes shown but the last is hidden behind the colored reflector, which you will need to pry off. It is easy to remove with a small flathead screwdriver. Of the four screws, two are 18mm and the other two are 52.5mm long.
  2. 2001-2006 Mini Cooper Door panel Replacement: étape 2, image 1 de 2 2001-2006 Mini Cooper Door panel Replacement: étape 2, image 2 de 2
    • With the screws removed, you will need to pry the panel off of the door using a prybar or flathead screwdriver. I wrapped my screwdriver in electrical tape to keep it from scratching the car.
    • The bottom and sides of the panel are held on with one type of clip while the top is held on by another. Because of this, you want to start prying it somewhere along the bottom edge of the panel, I chose the lower outside corner.
  3. 2001-2006 Mini Cooper Door panel Replacement: étape 3, image 1 de 2 2001-2006 Mini Cooper Door panel Replacement: étape 3, image 2 de 2
    • Once you have the bottom and sides of the panel popped off the tabs, you want to to a combination of lifting and pulling along the top edge to remove it from these other types of tabs.
    • Once the panel is free from these, you can slide it over the door lock knob and pull the whole thing away.
    • That's it. You now have access to the rest of the door. In order to put the panel back on, just follow these directions in reverse order.
5 autres ont terminé cette réparation.
Eliot Kahn
Membre depuis le 10/09/13
575 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-19, Regan Fall 2013 Membre de l'équipe Cal Poly, Team 8-19, Regan Fall 2013
CPSU-REGAN-F13S8G19
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 22
30 derniers jours : 58
Total : 22,577
