Aller au contenu principal
2002-2008 Dodge Ram 1500 Fuse Replacement
Ce dont vous avez besoin
  1. 2002-2008 Dodge Ram 1500 Fuse Replacement, 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 1, image 1 de 3 2002-2008 Dodge Ram 1500 Fuse Replacement, 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 1, image 2 de 3 2002-2008 Dodge Ram 1500 Fuse Replacement, 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 1, image 3 de 3
    • Open the hood by pulling the hood lever in the driver-side footwell.
    • Reach under the center of the grille and press the hood latch.
  2. 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 2, image 1 de 2 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 2, image 2 de 2
    • Locate the fusebox. The fusebox is the box that says "Fuse and Relay Center", near the left front fender of your Dodge.
    • Unscrew the plastic nut that holds the cover of the fusebox in place.
  3. 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 3, image 1 de 3 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 3, image 2 de 3 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 3, image 3 de 3
    • Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check.
    • Locate the fuse grabber. The fuse grabber is located near the front of the fusebox.
    • Remove the fuse grabber from its holder.
  4. 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 4, image 1 de 2 2002-2008 Dodge Ram 1500 Fuse Replacement: étape 4, image 2 de 2
    • Use the fuse grabber to carefully pinch the fuse.
    • Pull the desired fuse out.
    • Be sure to replace each blown fuse with a fuse of the correct current rating and size. Serious damage can occur if the wrong fuse is used.
To replace a fuse, follow these instructions in reverse order. Make sure you buy the correct fuse to replace a blown fuse. Serious damage can occur if you do not use the correct replacement fuses.
11 autres ont terminé cette réparation.
Michael Saggese
Membre depuis le 10/05/12
1 021 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-24, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 membres
11 tutoriels rédigés
21 commentaires
Thank you for making the instructions simple and to the point!
Sierra W - Réponse
not what i was looking for but thank you
eimerben - Réponse
I need to find the flasher
Goldie Sandlin -
thanx anyway. but not the answer I wanted. didn't tell me anything about which fuse it was .I looked in the fuse box and didn't c the fuse labled headlight there...
Marc A. Moore - Réponse
I'm trying to fine the fuse for the dashlights on a 2008 dodge ram 1500 hemi
Peggy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 52
7 derniers jours : 298
30 derniers jours : 1,535
Total : 130,801
