Aller au contenu principal
2003-2007 Honda Accord Key Fob Battery Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: étape 1, image 1 de 3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: étape 1, image 2 de 3 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: étape 1, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
  2. 2003-2007 Honda Accord Key Fob Battery Replacement: étape 2, image 1 de 3 2003-2007 Honda Accord Key Fob Battery Replacement: étape 2, image 2 de 3 2003-2007 Honda Accord Key Fob Battery Replacement: étape 2, image 3 de 3
    • Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
    • Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
    • Remove the bottom portion of the key fob.
  3. 2003-2007 Honda Accord Key Fob Battery Replacement: étape 3, image 1 de 3 2003-2007 Honda Accord Key Fob Battery Replacement: étape 3, image 2 de 3 2003-2007 Honda Accord Key Fob Battery Replacement: étape 3, image 3 de 3
    • Remove the inner portion of the key fob.
  4. 2003-2007 Honda Accord Key Fob Battery Replacement: étape 4, image 1 de 3 2003-2007 Honda Accord Key Fob Battery Replacement: étape 4, image 2 de 3 2003-2007 Honda Accord Key Fob Battery Replacement: étape 4, image 3 de 3
    • Use your fingers to undo the clips at the top and bottom of the fob's inner portion.
    • Separate the two sides of the fob's inner portion.
  5. 2003-2007 Honda Accord Key Fob Battery Replacement: étape 5, image 1 de 3 2003-2007 Honda Accord Key Fob Battery Replacement: étape 5, image 2 de 3 2003-2007 Honda Accord Key Fob Battery Replacement: étape 5, image 3 de 3
    • Use a flathead screwdriver to pry up the circular battery.
    • Remove the key fob's battery.
3 autres ont terminé cette réparation.
eCuration
Membre depuis le 05/19/17
376 693 Réputation
234 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 767 tutoriels rédigés
Un commentaire
Very clear and helpful video. Everything worked the way it was shown. Cost was less than $5 for battery, found at Walgreens. Thank you!
Debra Burrell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 44
7 derniers jours : 274
30 derniers jours : 1,467
Total : 141,430
