Aller au contenu principal
2005 Honda Accord Opening Hood Guide
  1. 2005 Honda Accord Opening Hood Guide, 2005 Honda Accord Opening Hood Guide: étape 1, image 1 de 2 2005 Honda Accord Opening Hood Guide, 2005 Honda Accord Opening Hood Guide: étape 1, image 2 de 2
    • Identify the open hood latch. It is located to the left of your brake pedal.
    • Pull latch toward you. You should hear a click from the front of the car.
  2. 2005 Honda Accord Opening Hood Guide: étape 2, image 1 de 3 2005 Honda Accord Opening Hood Guide: étape 2, image 2 de 3 2005 Honda Accord Opening Hood Guide: étape 2, image 3 de 3
    • Walk to the front of the car.
    • Slide your hand under the hood, just above the Honda logo. Feel for a small rectangular lever. Pull the lever up, and lift the hood.
    • Be sure to lift the hood all the way up, until the pneumatic braces hold the hood in place.
To close hood, lower to 6 inches above engine, then drop hood. If you do not hear the latch reengage, push down on hood or try dropping hood from a higher level.
4 autres ont terminé cette réparation.
Matt Ondriezek
Membre depuis le 04/14/14
486 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-35, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 membres
5 tutoriels rédigés
2 commentaires
Don’t you think that people usually access this guide when the hood is stuck closed? In which case these instructions are no more helpful than those in the owner’s manual. I’ve opened the hood of my 2005 Honda Civic countless times, until this morning. Interior release functions just fine, but the secondary release does nothing.
David - Réponse
Cable from inside hood release is broken need diagrams to show mechanism under driver's side fender to show how to replace it.
William McNeil - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 55
Total : 37,732
