Aller au contenu principal
2007 Chevy Aveo Indicator light bulb Replacement
Ce dont vous avez besoin
  1. 2007 Chevy Aveo Indicator light bulb Replacement, Indicator light bulb: étape 1, image 1 de 3 2007 Chevy Aveo Indicator light bulb Replacement, Indicator light bulb: étape 1, image 2 de 3 2007 Chevy Aveo Indicator light bulb Replacement, Indicator light bulb: étape 1, image 3 de 3
    • Here is a view of the left tail light assembly
    • Open the rear hatch,( or trunk if it is a sedan). On the inside of the assembly are two retaining screws. Remove those
    • both screws are #6x3/4 inch
  2. 2007 Chevy Aveo Indicator light bulb Replacement: étape 2, image 1 de 3 2007 Chevy Aveo Indicator light bulb Replacement: étape 2, image 2 de 3 2007 Chevy Aveo Indicator light bulb Replacement: étape 2, image 3 de 3
    • Here is a view of the assembly with the screws removed.
    • Insert some sort of prying tool between the tail light assembly and the body, just below the crease in the body and pry to the rear of the vehicle. a snap will be felt/heard as the plastic stud releases
    • Move the prying tool to above 1 1/2 inch above the bottom of the assembly. Insert it between the assembly and body and gently pry toward the rear of the vehicle. This should free the second stud.
  3. 2007 Chevy Aveo Indicator light bulb Replacement: étape 3, image 1 de 3 2007 Chevy Aveo Indicator light bulb Replacement: étape 3, image 2 de 3 2007 Chevy Aveo Indicator light bulb Replacement: étape 3, image 3 de 3
    • Now just pull the assembly straight back.
    • Avoid pulling the assembly to one side or another, that can snap the plastic studs
    • Locate the burned out bulb. In this case it was the indicator light. Rotate the bulb sockets in a counterclockwise direction.
    • Pull the sockets straight out of the tail light assembly.
7 autres ont terminé cette réparation.
oldturkey03
Membre depuis le 09/29/10
784 303 Réputation
119 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
33 membres
560 tutoriels rédigés
2 commentaires
This was a great help thank you!!
Jeffrey Blum - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 77
Total : 9,705
