Aller au contenu principal
2008-2013 Volkswagen Golf Tail Light Bulb Replacement
Ce dont vous avez besoin
  1. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate tail light compartment: étape 1, image 1 de 1
    • On the driver's side of the vehicle's rear cargo area, locate the rectangular tail light compartment cover.
  2. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove cover: étape 2, image 1 de 1
    • Using your fingers, gently pull the cover away from the compartment.
  3. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate the light bulb assembly: étape 3, image 1 de 1
    • With the cover removed, locate the light bulb assembly.
    • Use a flathead screwdriver to release the locking tab.
  4. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove the light bulb assembly: étape 4, image 1 de 1
    • Pull gently to remove the light bulb assembly.
    • The assembly will remain connected to the vehicle via the wiring harness.
  5. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate the light bulb: étape 5, image 1 de 1
    • Turn the assembly so that the smaller tail light bulb and larger fog light bulb are visible.
  6. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove the tail light bulb: étape 6, image 1 de 1
    • Using your fingers, gently pull the tail light bulb out of the socket.
    • Insert a new replacement light bulb into the tail light socket.
    • Excess force may cause light bulbs to break.
6 autres ont terminé cette réparation.
Jeffrey Jacquin
Membre depuis le 10/11/14
284 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-12, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-12, Donnelly Fall 2014
USFT-DONNELLY-F14S1G12
1 membre
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 82
30 derniers jours : 382
Total : 46,149
