Aller au contenu principal
2010-2014 Ford Mustang tire pressure maintenance
Ce dont vous avez besoin
    • Use a calibrated tire pressure gauge, typically one with a reset button, or a digital one, and measure the pressure of all four tires.
    • On the driver side door, there will be a sticker with the suggested tire pressure, mine was 35 psi, yours might be different.
    • Using a compressor add air to the tires as required. NOTE: all four tires should be at the same pressure. Also, final pressure measurements should be with the tires at ambient temperature.
    • Once you have determined the pressure in each tire is correct, replace the valve stem caps. When you get in the car and start it the alarm will still be on. Drive a few miles, and it should clear on its own.
    • This automatic clearing is NOT mentioned in the manual, and was not provided by the local Ford dealer. I found this by accident when I completed the above procedure.
    • If you have to replace a tire, and/or a Tire Pressure Sensor, there is a much more complicated procedure that is required. This procedure also requires the use of a TPS reset/Learning tool. The details for this procedure are available on the WEB.
Dave Bassett
Membre depuis le 12/05/14
133 Réputation
1 tutoriel rédigé
Un commentaire
When you say valve stem caps. Do you mean the tire caps? Just replace them or take them off and put them back on?
Christopher DeNigris - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 48
Total : 7,583
