Aller au contenu principal
360fly 4K SD Card Replacement
Ce dont vous avez besoin
  1. 360fly 4K SD Card Replacement, Battery: étape 1, image 1 de 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K SD Card Replacement: étape 2, image 1 de 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
  3. 360fly 4K SD Card Replacement: étape 3, image 1 de 2 360fly 4K SD Card Replacement: étape 3, image 2 de 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K SD Card Replacement: étape 4, image 1 de 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K SD Card Replacement: étape 5, image 1 de 2 360fly 4K SD Card Replacement: étape 5, image 2 de 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K SD Card Replacement: étape 6, image 1 de 3 360fly 4K SD Card Replacement: étape 6, image 2 de 3 360fly 4K SD Card Replacement: étape 6, image 3 de 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
  7. 360fly 4K SD Card Replacement, SD Card: étape 7, image 1 de 1
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. 360fly 4K SD Card Replacement: étape 8, image 1 de 1
    • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
  9. 360fly 4K SD Card Replacement: étape 9, image 1 de 1
    • Gently pry out the plug from the circuit assembly.
  10. 360fly 4K SD Card Replacement: étape 10, image 1 de 1
    • Press and release the SD card to remove it from the circuit assembly.
5 autres ont terminé cette réparation.
Jacob Herron
Membre depuis le 11/08/17
463 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S5-G3, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 membres
3 tutoriels rédigés
Un commentaire
Really useful guide, thanks
John Erikson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 18
Total : 1,083
