Introduction
This is one of the easier disassembly guides for this device. The case is easily removed, but will void any still existing warranty on the device. Removing the case is necessary to get at any internal component.
Pièces
Aucune pièce nécessaire.
Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool. Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool. Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
  • Pry 4 plastic feet off the bottom of the enclosure using the iPod opening tool.
Ajouter un commentaire
Unscrew the four screws previously covered by the feet. Unscrew the four screws previously covered by the feet.
  • Unscrew the four screws previously covered by the feet.
Flip the device right side up, then gently slide the casing upwards and off the hard drive. Flip the device right side up, then gently slide the casing upwards and off the hard drive.
  • Flip the device right side up, then gently slide the casing upwards and off the hard drive.
Flip device upside down again.
  • Flip device upside down again.
  • Gently pry the bottom gray casing away from the device.
Rotate so back of device is facing you, then gently pry the back casing away. When back casing is removed, the fan will become loose.
  • Rotate so back of device is facing you, then gently pry the back casing away.
  • When back casing is removed, the fan will become loose.
Patrick Meyer
Membre depuis le 10/04/2011
83 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-60, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 516
