Introduction
The back-facing camera is somewhat exposed on the device and therefore is susceptible to damage. Cameras are somewhat of a luxury on a device and may not be a crucial for extending the device's life, but a simple replacement is well worth the time.
Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet. Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
If you have a device with SIM card slot, remove SIM card first.
Hans-Josef Hoffmann - Réponse
Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward. The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons. The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
  • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
Ajouter un commentaire
Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
Remove back panel by pulling away from the remaining device. Remove back panel by pulling away from the remaining device.
  • Remove back panel by pulling away from the remaining device.
Use Tweezers to pull out gold flap connected to bottom of camera. Pull the gold flap to take out the camera.
  • Use Tweezers to pull out gold flap connected to bottom of camera.
  • Pull the gold flap to take out the camera.
Sandy Babich
Membre depuis le 23/09/2014
1 613 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 13-9, Forte Fall 2014 Membre de l'équipe Cal Poly, Team 13-9, Forte Fall 2014
CPSU-FORTE-F14S13G9
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 816
