Aller au contenu principal
ASUS F555UA-EH71 Battery Replacement
Ce dont vous avez besoin
  1. ASUS F555UA-EH71 Battery Replacement, Keyboard Panel: étape 1, image 1 de 1
    • Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
  2. ASUS F555UA-EH71 Battery Replacement: étape 2, image 1 de 2 ASUS F555UA-EH71 Battery Replacement: étape 2, image 2 de 2
    • Use your fingers to gently pry open the gap between the silver and black parts of the casing.
    • Separate the keyboard panel from the body of the laptop by wedging the iFixit Opening Tool in between the keyboard panel and the body.
    • The teeth of the casing should make a clicking noise as they’re pulled apart.
  3. ASUS F555UA-EH71 Battery Replacement: étape 3, image 1 de 1
    • Gently open the casing until the white, silver, and gold power strips are visible. Gently peel the strips from the bottom side of the laptop.
    • Disconnect the two cables connecting the keyboard panel to the laptop.
  4. ASUS F555UA-EH71 Battery Replacement: étape 4, image 1 de 1
    • Remove the keyboard panel from the laptop.
  5. ASUS F555UA-EH71 Battery Replacement, Battery: étape 5, image 1 de 3 ASUS F555UA-EH71 Battery Replacement, Battery: étape 5, image 2 de 3 ASUS F555UA-EH71 Battery Replacement, Battery: étape 5, image 3 de 3
    • Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
  6. ASUS F555UA-EH71 Battery Replacement: étape 6, image 1 de 2 ASUS F555UA-EH71 Battery Replacement: étape 6, image 2 de 2
    • Carefully remove the battery from the device.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 18
Total : 947
