Introduction
The removal of the battery is an essential bit of knowledge, since you will have to do this before most other repairs. Removing the battery first creates a safe environment to work in, which will eliminate most shock hazards.
Make sure the computer is turned off completely. Flip the laptop over with the bottom facing upwards. Remove all ten 3 mm Torx T-5 screws with the Torx T-5 screwdriver.
  • Make sure the computer is turned off completely. Flip the laptop over with the bottom facing upwards.
  • Remove all ten 3 mm Torx T-5 screws with the Torx T-5 screwdriver.
Ajouter un commentaire
Use the plastic spudger to wedge between laptop and back case. Lift upwards to pry open the back case. Run the spudger along the perimeter of the back case to remove.
  • Use the plastic spudger to wedge between laptop and back case. Lift upwards to pry open the back case.
  • Run the spudger along the perimeter of the back case to remove.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the three 4 mm JIS 0 screws using the JIS 0 screwdriver. Remove the three 4 mm JIS 0 screws using the JIS 0 screwdriver.
  • Remove the three 4 mm JIS 0 screws using the JIS 0 screwdriver.
Using both hands, lift the battery vertically out of the device. Using both hands, lift the battery vertically out of the device.
  • Using both hands, lift the battery vertically out of the device.
Steven Hahn
Membre depuis le 29/01/2018
704 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S5-G1, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 61
