Introduction
This guide will teach you how to replace the RAM stick from the device. You may need to replace the RAM stick if you notice performance dips or corrupted file errors.
Make sure the computer is turned off completely. Flip the laptop over with the bottom facing upwards. Remove all ten 3 mm Torx T-5 screws with the Torx T-5 screwdriver.
  • Make sure the computer is turned off completely. Flip the laptop over with the bottom facing upwards.
  • Remove all ten 3 mm Torx T-5 screws with the Torx T-5 screwdriver.
Ajouter un commentaire
Use the plastic spudger to wedge between laptop and back case. Lift upwards to pry open the back case. Run the spudger along the perimeter of the back case to remove.
  • Use the plastic spudger to wedge between laptop and back case. Lift upwards to pry open the back case.
  • Run the spudger along the perimeter of the back case to remove.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the three 4 mm JIS 0 screws using the JIS 0 screwdriver. Remove the three 4 mm JIS 0 screws using the JIS 0 screwdriver.
  • Remove the three 4 mm JIS 0 screws using the JIS 0 screwdriver.
Using both hands, lift the battery vertically out of the device. Using both hands, lift the battery vertically out of the device.
  • Using both hands, lift the battery vertically out of the device.
Put on anti-static wristband and attach clip-end to any metal screw insert.
  • Put on anti-static wristband and attach clip-end to any metal screw insert.
  • The wristband is recommended when working closely with circuit boards due to potential static discharge.
The RAM will be secured by two metal clips surrounded by white plastic. Spread the metal clips and the RAM stick will pop up.  Then  gently remove the RAM stick. Spread the metal clips and the RAM stick will pop up.  Then  gently remove the RAM stick.
  • The RAM will be secured by two metal clips surrounded by white plastic.
  • Spread the metal clips and the RAM stick will pop up. Then gently remove the RAM stick.
Steven Hahn
Membre depuis le 29/01/2018
704 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S5-G1, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G1, Passmore Spring 2018
USFT-PASSMORE-S18S5G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 55
