Aller au contenu principal
ASUS PadFone X Battery Replacement
Ce dont vous avez besoin
  1. ASUS PadFone X Battery Replacement, Remove the back panel.: étape 1, image 1 de 2 ASUS PadFone X Battery Replacement, Remove the back panel.: étape 1, image 2 de 2
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Battery Replacement, Remove the screws.: étape 2, image 1 de 2 ASUS PadFone X Battery Replacement, Remove the screws.: étape 2, image 2 de 2
    • Remove the 13 - 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Battery Replacement, Remove the Mid-Frame: étape 3, image 1 de 2 ASUS PadFone X Battery Replacement, Remove the Mid-Frame: étape 3, image 2 de 2
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Battery Replacement, Remove the Battery Connector: étape 4, image 1 de 2 ASUS PadFone X Battery Replacement, Remove the Battery Connector: étape 4, image 2 de 2
    • Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Battery Replacement, Remove the battery.: étape 5, image 1 de 2 ASUS PadFone X Battery Replacement, Remove the battery.: étape 5, image 2 de 2
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
4 autres ont terminé cette réparation.
John Kue
Membre depuis le 10/07/14
379 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 8-4, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 5,102
