Introduction
This guide will show how to remove the back cover, with the integrated antenna, to replace it.
Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards. Work your way around the phone until the entire back cover is loose.
  • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
  • Work your way around the phone until the entire back cover is loose.
Ajouter un commentaire
Replace the back cover with the new one; the antenna is integrated with the back panel.
  • Replace the back cover with the new one; the antenna is integrated with the back panel.
John Kue
Membre depuis le 07/10/2014
358 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 8-4, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 8-4, Leahy Fall 2014
USFT-LEAHY-F14S8G4
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 6
Total : 815
