Introduction
Replacement of the SSD.
Pièces
Aucune pièce nécessaire.
  • METHOD 1: Use a plastic pry tool to pop the back of the tablet off. Be careful the aluminum back is attached via plastic hooks.
  • METHOD 2: Access by removing the screen (suggested by Quantum Byte)
  • If like me you are unable to find a gap to detach the aluminium back from the frame so instead I tried accessing by removing the screen using a sharp tool (a metal blade such as a Stanley knife or a flat-ended spudger) as in the video (not my work).
  • Unfortunately, this is not as easy as in the video as the entire outer edge seems to be glued. Furthermore, the screen cracks v. easily. Since my screen was already damaged, I ended up breaking up and tearing the screen off. I am perhaps not best to advise on this method.
  • I suggest using a hair dryer/ heat gun to melt the glue sufficiently to make the screen detach.
Hello, can you add some pictures of the operation for opening the cover ?
thanks
Alessandro
Alex - Réponse
Sorry I do not own the tablet anymore.
Sasa Macura - Réponse
To open the Cover of TransformerBook T300LA start at the hinge on the bottom-side of your Tablet, and open the 2 screws first. Then use a plastic spatula from a Smartphone-Repair-Kit. Be very carefully, the cover should open easily.
On following link you will find a helpfull video for opening: https://youtu.be/WFD_9xalh-g
ChristianR - Réponse
The battery is attached via 6 screws. They are clearly marked with location and screw size. The battery is attached via 6 screws. They are clearly marked with location and screw size.
  • The battery is attached via 6 screws. They are clearly marked with location and screw size.
Ajouter un commentaire
The SSD is a M.2 NGFF style with a size of 80mm. The label states 3.3v 2A. If replaced with a lower power drive battery life might increase.
  • The SSD is a M.2 NGFF style with a size of 80mm. The label states 3.3v 2A. If replaced with a lower power drive battery life might increase.
  • Unscrew the single screw on the end of the drive. Undo the tabs on the ribbon cable above it and take the ribbon out.
  • Remove the drive and replace with a larger new one.
3 autre(s) ont terminé cette réparation.
Sasa Macura
Membre depuis le 05/08/2014
147 Réputation
2 tutoriels rédigés
Note that this guide does not work for the Asus T300 Chi which has an eMMC solid state drive soldered directly to the motherboard - you will need an eMMC reader and skill in removing soldered components to do this. Recommend taking to a data recovery professional in this case
Quantum Byte - Réponse
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 32
30 derniers jours : 152
Total : 9,256
