Aller au contenu principal
ASUS X552LAV-BBI5N08 Screen Replacement
Ce dont vous avez besoin
  1. ASUS X552LAV-BBI5N08 Screen Replacement, Battery: étape 1, image 1 de 1
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Screen Replacement: étape 2, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 2, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 2, image 3 de 3
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Screen Replacement, Screen: étape 3, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement, Screen: étape 3, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement, Screen: étape 3, image 3 de 3
    • Remove the six 12mm screws located at both the battery area and the bottom panel, with a Tri-wing Y1 screwdriver.
    • Slide the bottom panel down and lift it up to remove.
    • Remove the seven 5.5mm screws located at the bottom area with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Screen Replacement: étape 4, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 4, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 4, image 3 de 3
    • Use an opening tool to split keyboard from base of the laptop.
    • Make sure to start from one end and go around the edges.
    • Flip laptop to sit on its bottom.
    • Lift keyboard up by the front edge.
  5. ASUS X552LAV-BBI5N08 Screen Replacement: étape 5, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 5, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 5, image 3 de 3
    • Flip up the small locking flap for the two ZIF connectors.
    • Unplug the connectors that are keeping the keyboard connected.
  6. ASUS X552LAV-BBI5N08 Screen Replacement: étape 6, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 6, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 6, image 3 de 3
    • Flip up the locking flap for the ZIF connector.
    • Unplug the connector.
  7. ASUS X552LAV-BBI5N08 Screen Replacement: étape 7, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 7, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 7, image 3 de 3
    • Flip laptop to sit with the screen on the bottom.
    • Use tweezers to remove the square decorative sticker from the top of screws from the edge of the screen frame.
    • Remove six 4mm screws (with a JIS #1 screwdriver) from under the stickers and both of the hinges.
  8. ASUS X552LAV-BBI5N08 Screen Replacement: étape 8, image 1 de 2 ASUS X552LAV-BBI5N08 Screen Replacement: étape 8, image 2 de 2
    • Release hinges with the motion of opening a book.
  9. ASUS X552LAV-BBI5N08 Screen Replacement: étape 9, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 9, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 9, image 3 de 3
    • Use an opening tool to pry apart the frame from the edge of the screen
    • Go around the edges til the frame pops off from the screen
  10. ASUS X552LAV-BBI5N08 Screen Replacement: étape 10, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 10, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 10, image 3 de 3
    • Remove eight 4mm screws from the corners of the screen using a JIS #000 screwdriver.
    • Flip the screen towards the bottom panel face down.
  11. ASUS X552LAV-BBI5N08 Screen Replacement: étape 11, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 11, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 11, image 3 de 3
    • Use tweezers to remove the tape from the top of yellow lock.
    • Open the yellow ZIF connector.
  12. ASUS X552LAV-BBI5N08 Screen Replacement: étape 12, image 1 de 2 ASUS X552LAV-BBI5N08 Screen Replacement: étape 12, image 2 de 2
    • Remove the tape completely from the back panel.
  13. ASUS X552LAV-BBI5N08 Screen Replacement: étape 13, image 1 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 13, image 2 de 3 ASUS X552LAV-BBI5N08 Screen Replacement: étape 13, image 3 de 3
    • Remove the casing from the edges of the screen by removing the eight 2mm screws with a JIS #000 screwdriver.
    • Pull the screen up to remove it.
Jason Vo
Membre depuis le 02/15/18
857 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S17-G1, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 365
