Aller au contenu principal
Acer Aspire 1410 Disassembly
Ce dont vous avez besoin
  1. Acer Aspire 1410 Disassembly, Acer Aspire 1410 Disassembly: étape 1, image 1 de 3 Acer Aspire 1410 Disassembly, Acer Aspire 1410 Disassembly: étape 1, image 2 de 3 Acer Aspire 1410 Disassembly, Acer Aspire 1410 Disassembly: étape 1, image 3 de 3
    • With laptop closed, turn screenside down and remove the battery.
    • Unscrew covers and remove HDD.
    • Unscrew cover and remove RAM.
    • Unscrew and remove cover for fan.
  2. Acer Aspire 1410 Disassembly: étape 2, image 1 de 1
    • Turn laptop so that hinges are closest to you and remove screw from rear of each hinge.
    • Remove screws securing bottom case to logic board. (It won't come off just yet though)
  3. Acer Aspire 1410 Disassembly: étape 3, image 1 de 3 Acer Aspire 1410 Disassembly: étape 3, image 2 de 3 Acer Aspire 1410 Disassembly: étape 3, image 3 de 3
    • Turn laptop over and open the screen fully. Take care as the screen is still connected to the logic board via black cable on right hinge.
    • Use a spudger to release the silver and black plastic cover that forms the hinge covers. Start at one side nearest a hinge and work along the rear of the case, there are 5 tabs to release along the keyboard edge.
    • Disconnect LCD cable by lifting straight upwards using the black plastic tabs on the top of the LCD connector. You may need to use a spudger to loosen the connection along the uppermost edge-not along the logicboard.
    • Remove 2 screws from left and right hinges.
    • Remove 2 screws securing topcase to rear of battery tray.
  4. Acer Aspire 1410 Disassembly: étape 4, image 1 de 3 Acer Aspire 1410 Disassembly: étape 4, image 2 de 3 Acer Aspire 1410 Disassembly: étape 4, image 3 de 3
    • Remove 2 screws securing power board to logicboard.
    • Lift LCD screen from bottom case.
  5. Acer Aspire 1410 Disassembly: étape 5, image 1 de 2 Acer Aspire 1410 Disassembly: étape 5, image 2 de 2
    • Remove 2 screws securing the keyboard to case.
    • Use a spudger to release tabs on all 4 sides of the keyboard. Do not pull keyboard up too far as the trackpad and keyboard flex cables are still attached to the logicboard.
    • Place ducks in sink, make sure to disinfect sink afterwards.
  6. Acer Aspire 1410 Disassembly: étape 6, image 1 de 3 Acer Aspire 1410 Disassembly: étape 6, image 2 de 3 Acer Aspire 1410 Disassembly: étape 6, image 3 de 3
    • Do not pull keyboard upwards as it is still attached to logicboard.
    • Flip keyboard over to cover trackpad. Disconnect keyboard.
  7. Acer Aspire 1410 Disassembly: étape 7, image 1 de 3 Acer Aspire 1410 Disassembly: étape 7, image 2 de 3 Acer Aspire 1410 Disassembly: étape 7, image 3 de 3
    • Disconnect trackpad.
    • Use a spudger to ease topcase free of bottom case. Slide topcase toward trackpad and then lift up. Resistance can be felt from magnets on topcase.
    • Your laptop should now look like this; middle photo is the remaining logicboard and bottom case, the last photo is the topcase cover.
  8. Acer Aspire 1410 Disassembly: étape 8, image 1 de 3 Acer Aspire 1410 Disassembly: étape 8, image 2 de 3 Acer Aspire 1410 Disassembly: étape 8, image 3 de 3
    • Remove logicboard screws.
    • Remove the 2 screws securing the modem.
    • Disconnect wire from the modem to the logicboard.
    • Disconnect the speaker wire form the logicboard.
  9. Acer Aspire 1410 Disassembly: étape 9, image 1 de 1
    • Use hex no.5 tool to unscrew 2 bolts from port next ac-in jack.
  10. Acer Aspire 1410 Disassembly: étape 10, image 1 de 3 Acer Aspire 1410 Disassembly: étape 10, image 2 de 3 Acer Aspire 1410 Disassembly: étape 10, image 3 de 3
    • Slide DVD drive from logicboard frame.
    • Slide logicboard toward trackpad and then lift out of logicboard frame. The logicboard has a pin connection to the battery tray preventing direct lifting of the logicboard.
    • Last 2 photo's show top of logicboard and underside of logicboard.
To reassemble your device, follow these instructions in reverse order. Remember to place logicboard in ac power connection end in first
22 autres ont terminé cette réparation.
pollytintop
Membre depuis le 06/09/10
77 149 Réputation
5 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 521 tutoriels rédigés
3 commentaires
superb thanx thanx thanx
thushararoshanperera - Réponse
Great start, but this is not my 1410 and there is no selection for other models. The one I have is much smaller. Mine is model 1410-2817.
William Nelson - Réponse
Great effort but my model does not mach, much smaller, 1410-2817.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 38
Total : 17,122
