Aller au contenu principal
Acer Aspire 4520-5464 Graphics Card Replacement
Ce dont vous avez besoin
  1. Acer Aspire 4520-5464 Graphics Card Replacement, Battery: étape 1, image 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Graphics Card Replacement: étape 2, image 1 de 2 Acer Aspire 4520-5464 Graphics Card Replacement: étape 2, image 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Graphics Card Replacement: étape 3, image 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: étape 4, image 1 de 3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: étape 4, image 2 de 3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: étape 4, image 3 de 3
    • Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
    • Set the screws aside.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Graphics Card Replacement: étape 5, image 1 de 1
    • Unscrew the four 0.5mm Phillips #1 screws located on the heat sink in numerical order, as labeled on the device.
  6. Acer Aspire 4520-5464 Graphics Card Replacement: étape 6, image 1 de 1
    • Using the traditional 2.5mm screwdriver, rotate the locking tab counterclockwise to unlock the graphics card.
  7. Acer Aspire 4520-5464 Graphics Card Replacement: étape 7, image 1 de 2 Acer Aspire 4520-5464 Graphics Card Replacement: étape 7, image 2 de 2
    • Lift up the heat sink line and remove the graphics card.
2 autres ont terminé cette réparation.
Hunter Gilcrease
Membre depuis le 09/21/17
367 Réputation
3 tutoriels rédigés
Équipe
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S5-G117, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G117
3 membres
7 tutoriels rédigés
Un commentaire
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
Fernando Rodrigues - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 15
Total : 2,359
